AH FabricationsVolks Autos
Results 1 to 7 of 7
    S4P4UL's Avatar
    Jan 2013
    Halifax, UK
    81
    Bi-Xenon Headlights Flickering Issue??
    As the title really, sometimes I get a flickering issue with the headlights, not always just sometimes. maybe 6/10 times it will flicker for 15-30mins of the drive, not constant flickering but a flicker then maybe 5 mins after another flicker? any one else have this problem??
    Feb 2013
    Wiltshire
    346
    very common problem tbh. Two possible faults - bulbs or ballast. If ballast, its stupidly expensive. But, its more likely the bulbs. My s4 had the same problem that it randomly flickered but was fine more often then not. Changed the bulbs and its been perfect ever since.
    Get some new bulbs and you will be fine!
    27,094
    As above tbh, try turning them of then on again & see if the issue goes, usually bulbs, but be careful buying cheap tat as the ones I had of hids direct were a nightmare, prolonged usage they started not turning on again, then the 6k vision was terrible, bought the real McCoy from hids direct & havnt looked back since, great vision & not one flicker.
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    822
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    Had this issue last year, changed the bulbs and upgraded to 8000k (I preffered the blueish light output) from Trups and problem solved!
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    S4P4UL's Avatar
    Jan 2013
    Halifax, UK
    81
    Has anybody got a link to where I can buy they from? Is there a big difference between OEM and 6000k?
    Dec 2011
    145
    Quote Originally Posted by S4P4UL View Post
    If you want the very best quality bulbs then buy Philips or Osram bulbs. However DO NOT buy them from the dealership as they are >£100+vat for EACH bulb!!! I bought a pair of Osram Xenarc cool blue 5000k, they are perfect...not blue, more like a crystal white and they make the stock 4300k's look like Halogens! They cost around £100 per bulb from UK or buy them from Germany for 65 euros each from amazon.de
    OSRAM Xenarc Cool Blue Intense D1S (single) | PowerBulbs
    Osram 66144CBI Xenarc Coolblue Intense 12V 35W PK32D-2 Kraftfahrzeug-Lampe: Amazon.de: Auto
    EDIT: cheapest i can find them in UK is £85 but still cheaper to buy them from Germany
    Replacement Osram D1S Cool Blue Intense Upgrade Cool Blue Intense...
    2005 Audi A4 2.0 TDi SE
    oem bi-xenons with AFS & autolevelling
    oem balance shaft replacement
    oem rear parking sensors
    oem auto-dimming rear view mirror
    Shark STS Remap 170 bhp
    18" S5 style alloys
    H&R lowering springs
    TP-70 DIY Tyre Pressure Monitoring System
    V6 Quatt's Avatar
    Feb 2008
    783
    I would try bulb first. But change the pair if you can. I got pair of OEM 4300k for £75 on ebay
    Torque the Torque
  1. Xenon headlight issue
    By quattrov6tdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th April 2013, 22:41
  2. Xenon Headlight Issue
    By S3_Olly in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2012, 09:41
  3. s4 xenon headlight issue
    By therealnovaboy in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th September 2009, 12:19
  4. Failed MOT with a Xenon headlight alignment issue
    By chief_b in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2006, 18:40
  5. Xenon Headlights
    By wascal in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th October 2003, 21:43
