Results 1 to 30 of 30
    Jul 2012
    192
    Changed my Diverter valve yesterday
    Following this post last year:
    Intermittent Turbo Audi A4 2.0 FSI
    I finally got my diverter valve changed on my 2.0T FSI
    Got it done at a local place and it took about 10 minutes to do, I was able to keep hold of the old valve.
    It actually doesn't look too bad:
    Looking at the valve above I was a bit disappointed, not to see damage like others have seen on their valves.
    BUT the difference in the pick up of the car is amazing!!!! I must say if you have this engine it is WELL WORTH replacing. For a small price it gives great benefit. I can really feel the power in the car now
    Just wanted to say a quick thanks to all that helped me on here.
    Apr 2013
    Outer Manchester
    33
    Good stuff mate mine was exactly like that, no apparent tears in the one I removed but the difference in the drive was fairly noticeable!
    I nipped up all the intercooler hoses whilst I was under there as well for good measure.
    /// B7 Avant 'Quartzgrau'
    flickr
    Jul 2012
    192
    nice one
    good to hear that yours was similar too
    car really flies now
    you done a remap yet?
    Molnboman's Avatar
    Well done.....if you are getting a remap you would need to have it done anyway. You have pulled the valve apart haven't you to check for skirt damage?
    BR
    Allan
    Apr 2013
    Outer Manchester
    33
    I'll definitely be having it mapped in due course bud, just going about the usual weak spots first (DV/PCV/cam follower etc..)
    After a couple of tanks of V-Power and some Archoil 6400 (fuel system cleaner) it seemed better too, I imagine the previous owner ran it on 95RON.
    I pulled my old DV in bits Allan, no tears at all. It looked fairly new to be honest, so it did surprise me that the car was pokier straight away
    flickr
    Molnboman's Avatar
    Good man Pat...That must have been replaced before. Check the number on the side and google. I'd be a Monkey's Uncle if that was the original! Mine's was completely sh@gged at 110,000miles! Aye, the updated model is a millions times better and you'll need it anyway for the remap.
    Allan
    Apr 2013
    Outer Manchester
    33
    The one I pulled was a revision C, replaced with a piston type revision D. Let's see how long this one lasts! Car has 51k miles
    flickr
    Jul 2012
    192
    Quote Originally Posted by Molnboman View Post
    BR
    Allan
    yes pulled apart - there is no obvious damage to the insides of the valve
    must be the new design that is better and helps the car pick up more acceleration
    what would be the first thing to change or do to get a remap?
    Molnboman's Avatar
    Quote Originally Posted by psd99 View Post
    I thought there was an inbetween revision of diverter valve before the latest one....maybe I am wrong there.
    Quick Answer: You just done it Mate!.....Am no expert but if you are getting a re flash ecu upgrade wether it's a Shark, APR, BSR or MTM it will max at Stage 1, take you to around the late 240's bhp on a 2.0t. There's nothing to upgrade other than the diverter valve at that power. You should keep an eye on your PCV and if that goes you should cap it off or replace it. Clearly, it's gonna put a bit more stress on your clutch and brakes and stuff......but nothing more you need to do as long as you have it in good mechanical order. Maybe new Plugs, fresh oil wouldn't do any harm, and check your cam follower for wear....only thing I was advised was to make sure I only use 98 ron fuel and let the turbo cool down before switching the ignition off, as clearly it will be working a bit harder with the extra horses.
    A
    Jul 2012
    192
    A
    thanks mate
    I will read more into it
    the car flew home haha
    ANDYTQ's Avatar
    Oct 2003
    Caerdydd, Cardiff, United Kingdom, United Kingdom
    925
    Just changed mine , power was way down I knew what it was and had a d revision valve waiting to be fitted , wow what a difference now its absolutely flying now.
    06 A4 AVANT QUATTRO 2.0T S-LINE SE,GARNET RED, RS4 REAR ARB,SPACERS ALLROUND,H & R SPRINGS,B5 PERCHES,A6 V8 RIMS.PORSCHE CAYENNE TURBO S SIX POTS .REVO MAP ,STATIS CATBACK EXHAUST,PANEL FILTER.
    V.A.G.erbond's Avatar
    Spooling
    Nov 2012
    Leeds
    129
    Hi need advice please would you all recommend a revision d over the forge or turbo revs and other such valves? I need to do this mod but not sure which is the best to go for?
    Molnboman's Avatar
    [QUOTE=V.A.G.erbond;1935739]Hi need advice please would you all recommend a revision d over the forge or turbo revs and other such valves? I need to do this mod but not sure which is the best to go for?[/QUOTE
    The revised VAG OEM diverter valve is the cheapest and is very good and can handle loads of extra horses if your tuning, so I don't see why you need to go for aftermarket myself but that's my opinion.
    Allan
    Spooling
    Nov 2012
    Leeds
    129
    Thanks for that will get rev d
    Jul 2012
    192
    It will make a significant difference, even if the valve in there is perfect!
    Spooling
    Nov 2012
    Leeds
    129
    Called TPS for a price for rev d £50 +vat. So ordered same part from eBay £47 delivered.
    Jul 2012
    192
    Quote Originally Posted by V.A.G.erbond View Post
    good work I spent about £60 from ebay I think must have reduced in price.
    Jul 2013
    West Mids
    52
    What is the part number please ?
    Jul 2013
    Birmingham, UK
    44
    Really want to get mine changed now!
    Spooling
    Nov 2012
    Leeds
    129
    Here's my link also shows part no.
    http://item.mobileweb.ebay.co.uk/vie...d=261250273755
    maikysupra's Avatar
    May 2013
    Oxfordshire
    102
    Would anyone happen to know where I could buy the Rev D Diverter Valve for my Cab B7 1.8T? All I can see is everyone talking about DVs for 2.0 (checked other forums too) but haven't been able to find anything for my 1.8T yet... I could imagine that the one for 2.0 would not fit my engine, so is my only option to get it directly from Audi dealer?
    UberFiz's Avatar
    May 2013
    SE London
    32
    I got mine from Awesome GTI. The original DV was in pretty good condition but it feels much better with the revised version.
    Spooling
    Nov 2012
    Leeds
    129
    Ordered on Friday arrived this morning. Can't fit it until Weds though. Will update when fitted.
    maikysupra's Avatar
    May 2013
    Oxfordshire
    102
    Quote Originally Posted by UberFiz View Post
    Thanks UberFiz! I just checked their website and the only DV I can see for my engine is the £130.80 APR R1 DV... Is that the one you had in mind? If so I was hoping for the cheaper OEM Rev D instead;(
    Spooling
    Nov 2012
    Leeds
    129
    Quote Originally Posted by maikysupra View Post
    Goapr website £117
    maikysupra's Avatar
    May 2013
    Oxfordshire
    102
    Goapr website £117
    I'm sorry guys if I'm missing something obvious here, but I'm still seeing only suggestions for the aftermarket APR diverted valve... Does it mean that I can't buy the OEM rev D unless I go to the dealer, or perhaps there is not even a rev D DV for my engine at all??? I would really appreciate if someone could clarify this for me...
  28. #27
    Big Al's Avatar
    4wd + turbo = fun!
    May 2011
    West Midlands
    222
    The older 1.8T engine has a completely different diverter valve. The OEM ones are rubbish, buy yourself a Forge one. Black for OEM look, FMCL007P or newest, more efficient design is FMDV008 Forge Motorsport | Alloy Fabrication
    If you wish to have it fitted, Awesome are good - Forge 008 Diverter Valve for VAG 1.8 20v Turbo and 2.7T - A4 (B7) - Audi - Shop By Car
    Audi A4 B7 2004 red 2.0 TFSI Quattro Sport saloon, Servotronic steering, MFSW, CDIS, DRL with Coming Home, auto dual xenon lights/wipers/mirrors, split folding rear seats, 3rd headrest, centre armrest, Isofix mounts, RS4 rear ARB, pedals & carbon dash trims; Audi TTS 9Jx18alloys (2 sets), Yokohama AD08 summer, Conti TS830P winter 245/40/18 tyres, TPI 15/20 spacers/lockers, Pipercross filter, GFB DV+ turbo valve, NGK BKR7EIX plugs, Osram Silverstar Xenarc D1S bulbs. Build thread
  29. #28
    maikysupra's Avatar
    May 2013
    Oxfordshire
    102
    Thanks Big Al! So at least I know that my best option is to go aftermarket... I believe, I've heard somewhere that the forge DVs suffer from stuck piston issues a lot. The APR R1 seem to be pistonless system. Would you still Recommend the Forge over APR? Reliability for me is paramount ( CVT tranny doesn't allow me to do much with my tuning ambitions anyway
  30. #29
    Spooling
    Nov 2012
    Leeds
    129
    I ran the forge for a few years without issue. They are easy to maintain especially because of where it is mounted overall a great piece of kit.
  31. #30
    Jul 2013
    Birmingham, UK
    44
    Is there a trick to getting the clip off the connector? Don't seem to be able to shift it.
  1. Diverter valve changed
    By rgvsam81 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 6th July 2013, 18:15
  2. Is there a how to guide to chang the diverter valve please?
    By btcc2000 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 24th October 2011, 16:54
  3. Changing Diverter Valve
    By cameron1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd April 2009, 20:10
  4. Whats the best diverter valve for.....
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2003, 17:24
  5. Diesel Diverter Valves
    By simmolee in forum Diesel forum
    Last Post: 10th April 2003, 17:22
