Badger5EM Tuning
    Dec 2012
    Birmingham
    295
    Visit SinghB7's Instagram Channel
    Xenon headlamp retrofit problems
    I've fitted the oem headlamps and installes the kufatec loom all correctly.
    now when coding with vagcom im changing the code from halos to bi xenon but when it's selected and click do it and go back to the last menu, the code don't save. I go back on to the headlight coding and its stays as my old halo headlamp code.
    any one shed any light on this as i'm driving to holland in 2 days and need it sorting
    thank you
    Dec 2012
    Birmingham
    295
    Any one? Really need some help on this.
    Dec 2011
    147
    Not sure if this has anything to do with it but I take it you got a new central electrics module fitted? Because the existing CEM won't operate the bi xenons (at least on the poverty spec SE)
    2005 Audi A4 2.0 TDi SE
    oem bi-xenons with AFS & autolevelling
    oem balance shaft replacement
    oem rear parking sensors
    oem auto-dimming rear view mirror
    Shark STS Remap 170 bhp
    18" S5 style alloys
    H&R lowering springs
    TP-70 DIY Tyre Pressure Monitoring System
    Dec 2012
    Birmingham
    295
    I havn't no, mine is a s line
    the xenons fire up but either one will go off after
    just the codes on vcds arn't saving when I change them for halogen to bi xenon
    Dec 2012
    Birmingham
    295
    Bump
  1. Retrofit of genuine xenon headlamps & aftermarket HID kit.
    By o0timbo0o in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th November 2011, 21:28
  2. Xenon headlamp levelling problem since refitting.
    By jayjay in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th March 2011, 09:23
  3. Xenon Headlamp problem
    By vagman in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th January 2007, 23:00
  4. Cruise control retrofit problems
    By moogie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th February 2006, 21:35
  5. Xenon headlamps
    By Pontio in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2005, 16:55
