Monster MotorsportBadger5
    Jul 2013
    rear sensor problems after resetting even worst
    So the problem was two rear sensors weren't working,(checked for pulsing) so i decided to do a scan and after first scan i've got this:
    4 Faults Found:
    01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 18
    Reset counter: 95
    Mileage: 0 km
    Time Indication: 0
    Date: 2000.01.01
    Time: 00:00:00
    01549 - Supply Voltage for Parking-Aid Sensor
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 30
    Reset counter: 159
    Mileage: 0 km
    Time Indication: 0
    Date: 2000.01.01
    Time: 00:00:00
    01548 - Sensor for Parking Aid; Rear Right (G206)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 39
    Reset counter: 93
    Mileage: 0 km
    Time Indication: 0
    Date: 2000.01.01
    Time: 00:00:00
    002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 3
    Fault Frequency: 27
    Reset counter: 159
    Mileage: 0 km
    Time Indication: 0
    Date: 2000.01.01
    Time: 00:00:00
    then i reset faults and after that i've got this:
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 190
    Mileage: 0 km
    Time Indication: 0
    Date: 2000.01.01
    Time: 00:00:00
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 190
    Mileage: 0 km
    Time Indication: 0
    Date: 2000.01.01
    Time: 00:00:00
    when ignition on and in reverse i tried to hear does any of them working and non of them were working anymore. what's happened? and how to fix it?
    Feb 2013
    Wiltshire
    345
    Check your connections. I had to replace all my rear sensors not long ago with those errors.
  1. REAR SENSOR PROBLEMS
    By MR B A3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th May 2012, 16:27
  2. Replies: 5
    Last Post: 16th January 2010, 15:03
  3. Replies: 0
    Last Post: 15th January 2010, 16:10
  4. Rear Parking Sensor Problem
    By capercaillie in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th October 2007, 18:03
  5. Oil Sensor + Cruis Control Problems (after new ECU)
    By griffin1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st August 2006, 09:35
