Monster MotorsportChris Nott
Results 1 to 16 of 16
Like Tree3Likes
  • 1 Post By NHN
  • 1 Post By NHN
  • 1 Post By NHN
Thread: New owner, rough idle, black smoke, hesitation - help/ideas needed please!
    Jul 2013
    East Lancs
    46
    Hi everyone, I'm hoping to call on your collective experience and expertise. I'm 4 weeks into owning a 2007 A4 TDI 170 s-line quattro special edition. Great car, big improvement on my previous A3 but from day one I've experienced a problem that has yet to be solved.
    Symptoms
    • Rough/lumpy idle (intermittent), jumps between 900 and 1000 rpm
    • Engine shakes when idle is rough
    • Black smoke (excessive) - both on idle and under acceleration, chokes cyclists who get overtaken
    • Hesitation/flat spots - particularly in 3rd gear, at low revs, but car pulls well at high revs to the red line
    • All appear when engine cold or hot
    • No warning lights show (like DPF, check engine)
    • No error codes
    Fixes/inspections so far
    • Audi garage ran diagnostics, no error codes, say nothing wrong with car on a test-drive, confirmed injectors had been replaced under the recall 18 months ago, weren't interested in problems
    • Independent garage run full diagnostics, no error codes, but thought it may be egr cooler. Ran overnight pressure test, said engine/injectors were fine but cleaned manifold out, said it needed a 'good run down the motorway for a few hundred miles (the dealer I bought it from arranged all of this and weren't tech-minded so I'm not sure what 'manifold' he cleaned but he spent a day looking over it, told them if the problem persisted he could do a 'de-coke')
    • I dumped a can of BG244 into a full tank of V-Power to see if it would make any improvement (mpg seems to be better)
    . . . but the symptoms are still there. The dealer I bought it from did go out of their way to help, taking it to Audi and, not satisfied with their explanation, taking it to another independent specialist because they could see the symptoms and thought it wasn't quite right. However, all say there's nothing wrong with the car but I refuse to believe it as extensive google searches bring back lots of cases of similar symptoms but few solutions. The dealer I bought it from were really helpful if severely lacking in mechanical knowledge so wouldn't question any hypothesis thrown at them by a mechanic and aren't very local to me so I'd prefer to arrange any further investigations myself.
    Any ideas, anybody?!
    The other thing I've seen is a few companies doing re-map, DPF delete and EGR delete specifically on the TDI 170. Has anybody had this done and is it a potential solution?
    Thanks in anticipation.
    27,129
    Boost leak as black smoke is poor combustion.
    gupsterg likes this.
    Jul 2013
    East Lancs
    46
    Thanks NHN. I guess that could be a simple fix, tricky to find, and something so basic any garage should have considered?! Audi’s attitude of ‘no error codes = nothing wrong’ has been a big disappointment.
    The other thing I’ve noticed, on changing gear it sounds like it’s got a dump valve, venting to atmosphere, is this normal for this engine? I can hear the turbo spool/whistle but my other car was an impreza so I’m used to all of the whistles/whooshes/pops that made but don’t know what is abnormal for the TDI 170 engine.
    markyp2002's Avatar
    Oct 2006
    Burntwood
    301
    Sounds like your recirculating diverter valve is faulty to me (forgive me if im talking rubbish here, im sure this is the case). I had a similar issues on an old 1.8T Audi A3, changed the diverter valve and that fixed the atmospheric sound, never had any error messages or anything and it didn't seem to effect performance too much in either case!
    A4 B7 2.0 TDi S-Line Special Edition Gloss Red, BOSE, 18" Black RS4s, Black / Grey Leather, Sat Nav
    Jun 2013
    22
    Im in a similar situation with an A3 iv just brought, same year and engine i believe.
    Idle issues, clear smoke, hesitation and DPF error codes.
    Hope you get it resolved!
    Molnboman's Avatar
    Engine shaking at idle?....sounds like your dual mass flywheel may be going "bye bye" too. Does your car vibrate heavily in first and second gear? Tell tale signs that your Flywheel is f@cked Matey. Is there any noise difference when you press the clutch in, when in gear?
    BR
    A
    Jul 2012
    South London
    24
    Coil pack?
    27,129
    Quote Originally Posted by d4dubs View Post
    Coil pack?
    Its a TDI.
    Jul 2013
    East Lancs
    46
    Quote Originally Posted by Molnboman View Post
    BR
    A
    Hi Molnboman, thanks for your input! There's no vibration/shake when accelerating, it just happens on idle, but it's intermittent. When the idle is steady at just above 900rpm the engine is also steady, no shake, but when the idle decides to jump up and down by 200-500 rpm it's accompanied by the engine shuddering. The engine switches off fine, ie: no shudder.
    The car accelerates well and pulls to the redline, but it has occasional flat spots/hesitation at lower revs, under 3,000 rpm. Somebody has suggested that perhaps the EGR valve isn't closing fully. I'm going to try and get my head under the bonnet when the rain stops and stand there scratching my chin in anticipation of a light-bulb moment.
    Jul 2013
    East Lancs
    46
    Okay, so I took the top engine cover off and had a good look around, tugging/squeezing the hoses, all connections are tight and I can't see any obvious splits/holes in any of them. The only thing I noticed was the plastic air intake which feeds into the airbox wasn't properly sealed where it joins in the middle. See photo, I've outlined in red where it needed pushing together to get a better fit. I'm guessing this won't have much affect.
    I ran the engine for 10 minutes and revved it a few times but couldn't see/hear anything unusual. BUT, when I switched the engine off I could hear what sounded like some servos working away and a slight hissing noise, like air was being expelled for about 6 seconds. Is this usual after switching the engine off?
    Jul 2013
    East Lancs
    46
    Quote Originally Posted by MyMateDaveDJ View Post
    Thanks, good luck with yours, it sounds the same only I'm getting no error codes. When I find out what the problem is I'll post the answer on here, hopefully it might help other people with a similar problem.
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    280
    Quote Originally Posted by margin-walker View Post
    The slight hissing noise can be the air con circuit after shutdown ...
    Viewing of measuring blocks using VCDS or dealer VAS diagnostics machine maybe what you require to pin point problem ...
    Perhaps ask for a pressure test to be done on charge air system ...
    27,129
    You can actually, on some cars, activate the charge air system with vcds to try & help find leaks.
    gupsterg's Avatar
    Jun 2012
    280
    NHN I think you referring to the elements which can be tested by doing an output test in module 01? or do you mean it will check the intercoolers and related hoses? as that's what I referring to when stating get a pressure test done ...
    27,129
    Well there are a few tests, the basic setting in engine is one yes, but also a pressure/smoke tester is also a good one to use, I had the pleasure of using the dealer tool on my car on a weekend, nice piece of kit, no bloody leaks though lol.
    Jul 2013
    East Lancs
    46
    I have a new symptom: starting the car! ​I put the key in the ignition to start the car and it didn't start first time, I had to keep the key turned for a second longer the second time and it started. It's never done this before. Does this provide any more insight?! I'm going to search the forums now. Thanks for all of your help.
  1. 2.4 quattro A6 has hard brake pedal and very rough idle + smoke, any help please?
    By shufti in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 31st May 2013, 10:39
  2. Replies: 5
    Last Post: 27th January 2013, 12:56
  3. New owner saying hi and a bit of advice needed
    By tedster in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 29th October 2009, 16:47
  4. Crashed New A3 3.2 in an hour! Help with Bumpers Please!
    By magnus911 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th August 2007, 10:36
  5. Replies: 2
    Last Post: 30th July 2005, 01:51
