EM TuningChris Nott
Like Tree1Likes
  • 1 Post By jdp1962
Thread: front screen misting??
    May 2013
    60
    have real trouble with my front screen misting up in the early mornings, any one else have this issue? ive ordered some wind deflectors to crack the windows a little but even that doesn't cure it completely, unless I hit the front screen demist button which clears it straight away?? bugging me
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,312
    Sounds like you have some moisture in the car. Have you checked the carpets for dampness?
    NHN likes this.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs.
    May 2013
    60
    will check just to hopefully eliminate ;-(
    car doesn't smell damp or anything so hopefully not that, recently had a service and I know the pollen filter was done
    26,716
    As Jeff says, check for dampness, as this sounds like could be moisture, just hope its just minor blockage of leaves in engine bay or something & not leaking coolant system.
  1. Does anybody know how to get this off my front window screen ?
    By Digzz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th May 2013, 21:03
  2. front screen washer jet adjustment??
    By Chadders in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 2nd November 2012, 16:28
  3. Front screen?!
    By Jamie1985 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th February 2012, 18:39
  4. 2005 A4 CAB Front Screen Demister
    By Unregistered in forum Site Support & Announcements
    Last Post: 13th February 2011, 17:49
  5. front screen
    By 10blazin in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th June 2009, 23:35
