clarky87xx
i recently fitted cruise control to my audi a4 B7 2007 s-line. The fitting went great but when coming to code the cruise control via vag-com the engine 11463 always reverts back to 00000 is this meant to or should it stay as 11463. I also tested the components through the measuring blocks, wouldn't work at first because I was trying to access group 066 but after further investigating diesels are group 006 and petrol/gasoline are 066.
Anyways after testing bother the cruise switch and pedal switches, I get changes on all movements from the cruise switch and brake pedal switches which would indicate that these are all working correctly. When dipping the clutch and releasing it nothing changes, if im looking at the correct part it just stays as number 1.
does this mean the clutch switch is faulty and would that be a reason the coding is not changing to what it should be.
regards
karl
regards
karl
