Volks AutosJMB Retrofits
Thread: Revs itself
    Mar 2012
    17
    Revs itself
    Hi,
    Pulled up to park tonight from work and the engine is revving itself, from normal to about 1500 rpm and then back down. Drives ok, well no different than normal. Done a bit a reading and am I reading right that it could be the PCV Valve. Also read about the DV Valve. Anyone point me in the right direction? Also is she ok to drive as I need to get to work?
    oh, it's a 2.0 TFSi on an 05 plate
    boost-addict's Avatar
    Aug 2011
    977
    what they refer to "hunting" is usually down to the pcv
    sammi's Avatar
    verwood, Dorset
    346
    Follow sammi On Twitter
    does the clutch switch need replacing ? im sure its a common fault on the b7 2.0 tfsi, a friend had theirs replaced not so long ago because of reving on its own. im sure its not an expensive part to replace :0)
  1. Hesitation through revs
    By imported_Robbyc in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2006, 17:16
  2. engine goes flat at 3000 revs
    By ratty in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd May 2004, 02:21
  3. S3 rev hang-up
    By S3DCT in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th December 2003, 20:58
  4. Rev Matching
    By amoffat in forum Detailing
    Last Post: 3rd July 2003, 10:30
  5. rev limit?
    By Administrators in forum General Technical / How To
    Last Post: 3rd May 2003, 00:35
