AH FabricationsChris Nott
Results 1 to 8 of 8
    Jul 2013
    13
    cruise control help
    i have just installed cruise control and DIS switch to me B7 audi A4 s-line. The install went fine and upon firing up only light I had on the dash was ESP light, drove the car down the road and it went out. I then parked up to code the VCDS. I went in engine I think changed the coding section to 02002, something similar which was for multi function steering wheel and to switch on cruise. I then clicked on login-11 and typed in the code 11643 think it was to activate cruise. I exited and took it for a test drive and doesn't work. I plugged the cable back in and the code is still stored as 02002 (could be wrong just remember of top of my head but its correct as the help section states). I then ran a fault check which brings up these two faults,2 Faults Found:
    001384 - Cruise Control Switch (E45)
    P0568 - 000 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 3
    Fault Frequency: 1
    Mileage: 110258 km
    Time Indication: 0
    Freeze Frame:
    RPM: 924 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.08 V
    Bin. Bits: 00001100
    Bin. Bits: 00000000
    (no units): 0.0
    005785 - Powertrain Data Bus
    P1699 - 000 - Missing Message from Steering Wheel Electronics
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 3
    Fault Frequency: 4
    Mileage: 110258 km
    Time Indication: 0
    Freeze Frame:
    RPM: 903 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.08 V
    Bin. Bits: 00001100
    Bin. Bits: 00000000
    so im stumped and don't know whats wrong with it, thought it would have been simple but guess not any help will be appreciated. Car still runs fine as it is just the stalk doesn't work, its like its not even there.
    regards karl
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,074
    Your engine coding is wrong, should be 11463 not 11643. Once you key in the correct coding, log out of the controller and swith if your ignition for at least 30 secs.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,074
    Also you need to code the steering module 16. Change second last digit to 4 if you have trip and cruise.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,940
    Jul 2013
    13
    I've just coding in all the dis switch and that works great main problem I seem to be having is when clicking on coding-II it always reverts back to 00000 should it not stay as 11463
    Oct 2009
    Hull
    1,433
    follow the above link from start to finish if you dont do it all in the right order it wont work
    Jul 2013
    13
    I've been through that and still no luck, not got time until tomorrow but think next step is to check the measurements on the vcds of the clutch switch and the cruise control stalk
    Jul 2013
    13
    I've come to check the clutch switch and stalk operation with vcds today. But when I go into engine 01 the measur blocks the group 066 and click go it just searches and searches and never comes up
  1. Cruise control ???? Help please
    By Lambster in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th May 2013, 22:31
  2. A6 cruise control help
    By Ianb4310 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th April 2012, 20:43
  3. Cruise control help needed in manchester/oldham
    By RyanJonS4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th June 2009, 21:21
  4. Cruise control help needed in manchester/oldham
    By RyanJonS4 in forum VCDS (formerly VAG-COM) forum
    Last Post: 29th May 2009, 16:30
  5. Retro fit Lights and cruise control HELP PLEASE
    By fin in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th October 2007, 13:22
