Badger5Monster Motorsport
    Oct 2012
    Rear Driveshaft axle leak - costs to repair
    Hi all,
    Looking for a bit of advice on an oil leak found whilst having to change a wheel due to a puncture.... noticed that there was a leak in the quattro system that looks to be coming from the gasket between the centre housing and the driveshaft housing for the rear right hand wheel, circled in red in the below photo. The car is a 2005 B7 A4 Avant S Line 3.0TDI Quattro.
    Any ideas on what would be needed to repair this - is it usually just a gasket leak or is there likely to be something more serious? Any ideas on how much it'll cost to get repaired?
    Thanks for any advice / similar experiences.
    Phil
    Oct 2012
    Anyone?
    Apr 2011
    Somerset
    72
    sorry carn't offer any help with the leak as haven't encountered this problem on my car yet, might be worth calling up audi or an independent specialist see if there are any common problems with the system. good luck
    Oct 2012
    Hi, Thanks for the reply - that's basically my plan (Indy rather than Audi tho due to cost!) but was hoping someone on here may have had some experience of this so I have an idea of what to expect
  1. Rear bleed nipple leaking brake fluid?
    By Ian W in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th June 2008, 19:07
  2. 2004 Polo sdi rear wash pipe leak
    By S3 Dave in forum Volkswagen and other VAG
    Last Post: 17th February 2008, 16:56
  3. Quattro rear driveshaft inner cv joint / bearing play
    By Joni_s in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th July 2007, 09:27
  4. Damaged bumper - cost to repair???
    By imported_monkeytrousers in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th July 2004, 11:42
  5. Cost of repairs
    By imported_Ress4 in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 14th July 2004, 21:32
