Volks AutosJMB Retrofits
Results 1 to 25 of 25
    Oct 2009
    Hull
    1,440
    05 2.0 tdi juddering
    hey guys
    I have popped over from the B6 side to pick your brains
    My brother has an 05 2.0tdi 140 avant that has developed a problem
    it keeps juddering as if its misfiring! it does it a little at idle and it mainly does it when sitting between 1800 and 2000 rpm and accelerating through that rev range
    also it keeps going in to limp home mode if he boots it or when getting to near 80 mph which I think is overboost from sticking turbo vanes
    the turbo is a recent thing and I don't think its related
    anyone got any ideas?
    I am having a nosey at the weekend I have already had it on VCDS and all the injectors seem fine!
    Stu
    Jan 2012
    KERNOW
    107
    Engine mounts possibly?
    Feb 2013
    38
    i had this same problem on my 2.0tdi but it was only a very hard judder at idle...had my egr valve cleaned out and it solved the problem but i can slowly feel the judder coming back...
    Oct 2009
    Hull
    1,440
    Thanks for the replies
    It's not engine mounts as I say it's like it's a misfire and does it at a steady throttle too
    Egr has been cleaned too as that was my first thought
    May 2012
    93
    Quote Originally Posted by stu_m View Post
    try replacing the vacuum actuator on the inlet manifold, it has a rubber diaphragm that is prone to splitting, this cured mine.
    you can also clean the swirl flaps in the inlet manifold while you have got it off.
    Oct 2009
    Hull
    1,440
    Quote Originally Posted by hubbo1 View Post
    thats twice I have heard that now!
    where is this actuator located and is there a way to test it? would clamping the vac pipe on it confirm whether it is that or not
    May 2012
    93
    it is at the front of the engine on the inlet manifold, black plastic with small black vac pipe.
    you should be able to test it with a vacuum tester/brake bleeder kit
    Mar 2011
    North Wales
    207
    Here is a pic of actuator. Cost about £10 from TPS and another £10 if you want to replace the gasgets. Easy to do. You will need a couple of cans of choke cleaner too for the inlet manifold flaps. Cured mine of hesitation at around 1800rpm and limp mode fault code 299.
    May 2012
    93
    Quote Originally Posted by mm707 View Post
    hi
    I got my actuator from audi £11.94 p/n A03G 129 061 C
    Oct 2009
    Hull
    1,440
    I will check that out cheers
    Oct 2009
    Hull
    1,440
    Well I had a little nosey today and this car does not have this valve!
    May 2012
    93
    is the engine code blb? if so it will have this actuator, I will try and post a photo of the location
    Oct 2009
    Hull
    1,440
    Not sure on the engine code I will find out tomorrow
    Looking at the pic above its to the left of the alternator next to the cam belt cover
    May 2012
    93
    as you look into the engine it is just off centre to the right it is attached to the manifold
    Oct 2009
    Hull
    1,440
    Nope definitely not there
    Wonder if some have it and some don't
    Mar 2011
    North Wales
    207
    Mine is a 2007 so maybe it wasn't on the 2005 ?
    Have you checked the air filter ?, I read on another forum of someone having similar problems and it turns out his air filter was really clogged up - he changed it and fixed the problem.
    Oct 2009
    Hull
    1,440
    Yeah it's been changed along with the fuel filter too
    I took the car for a drive today and no juddering at all yet it was doing it for my brother on the way home from work
    Its going to get stripped tomorrow to check vac lines etc
    May 2012
    93
    mine is a 2005 140 tdi-strange yours hasn't got one
    Apr 2010
    SWINDON / WILTSHIRE
    72
    Had a look at mine today and I can't see one either.
    2005 BLB.
    Oct 2009
    Hull
    1,440
    I'm pretty sure this engine is a BLB too
    Its not my car so can't check at the min
    May 2012
    93
    [IMG][/IMG][IMG][/IMG] this is what is on my 2005 blb 2.0 tdi 140
    May 2013
    nairn
    how hard is it to change the actuator as mine is playing up at 1800rpm at low speed thanks
    May 2012
    93
    Quote Originally Posted by onearm35 View Post
    not too hard, egr valve has to come off then the inlet manifold, took me a couple of hours.
    Dec 2010
    11
    mines a 54 plate 2.0 tdi blb and mine does not have one too
    Mar 2012
    Essex
    118
    When you checked the injectors on VCDS did you do output tests while the car was running?
  1. A3 2.0 TDI Juddering HELP PLEASE
    By nick4575 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th May 2013, 20:08
  2. Odd Tdi judder :/
    By Best84 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th June 2012, 19:12
  3. Audi A3 2004 2.0 Tdi Juddering
    By ik1989 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th February 2012, 12:16
  4. 2004 A3 2.0 TDI juddering and struggling to start?
    By gizm0 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd December 2010, 17:54
  5. 2.0 TDI DSG Shuddering / Juddering!! HELP!!
    By joe90 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th December 2008, 07:24
