AH FabricationsVolks Autos
Results 1 to 9 of 9
Thread: speedo problem
    Apr 2010
    346
    speedo problem
    hi all,i had to take clocks out of the dash and the speedometer arm fell off so i took the cluster apart and put it back on,when i drove it wasn't reading right and then stooped working can i replace just the motor that controls it or do i need to replace the whole unit.
    27,089
    I reckon you've just pushed the motor of its cogs, take apart, look at rear motor & fit cogs back on if so, happens when you refit the needles.
    Apr 2010
    346
    I will try that tks,dose the nedle just push back on then or is there some sort of clip it didn't seem to lock in or any thing when I put it on
    27,089
    Its pushed back on, but when you push it can dislodge the rear motor cogs, so make sure cogs are all in place, refit housing & when putting needle back on make sure it doesn't dislodge whilst applying pressure.
    Apr 2010
    346
    hi nhn i took the back off the motor but in doing so bent the metal pieces inside and now no matter what way i fit it back it wont work,so back to my first question lol can i replace the motor its self.
    tks
    Apr 2010
    346
    ok with a bit of goooogling i found this Audi TT A3 A4 A6 VW Beetle Jaeger Magneti ... | Audi TT A3 A4 A6 Sp...
    will this work,car is a 2007 a4
    Apr 2010
    346
    May 2012
    RETFORD, NOTTS
    1,753
    Personally I'd replace the clocks, much easier by the look of those components!
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Apr 2010
    346
    Quote Originally Posted by @udi A3 View Post
    would that not just be a waste of money?i dont know the price of a set of clocks and i dont think i want to lol,i could change this part easy enough but just not sure if it the right one for my clocks
  1. A3 Speedo problems issues 1996-2003
    By caddypete in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th December 2011, 12:52
  2. A8 D3 speedo problem
    By spongefinger in forum A8/S8 forum
    Last Post: 4th December 2011, 21:56
  3. speedo problem
    By Crashlanding in forum General Technical / How To
    Last Post: 5th July 2008, 19:49
  4. A4 1.8 speedo problems
    By Jonny_doe in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th November 2004, 14:28
  5. speedo problems
    By imported_tacka in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th September 2004, 20:10
