Chris NottAH Fabrications
    Jul 2013
    Hydrolic fluid bottle location?
    Hi all, I bought my A4 2.4 Cabriloet 05 plate 2 months ago and I love it.However , yesterday as I was takingthe roof down it did all the motions such as windows down, unclipped at front and began to go back but just as the back cover lifted it stopped! I had to figure out ,with the help of some very kind passer byers and a smart phone and a google search,how to mauanlly put it back up again.Success! But I tried the roof again and the same thing happened.Now I am hoping that this is just a low on hydrolic fluid thing going on here but i cannot locate the hydrolic fluid bottle for the roof to check.I have search the boot for over an hour!!!!Can some one be so kind as to tell me where i could find it.
    All help much appreciated.
    Thanks in advance.
    Julia
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,664
    Welcome to the forum. I'm sure someone with a Cabriolet will be along shortly to give you the answer.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    27,029
    This is the reset procedure:
    ignition off
    remove the osf dash end cap where the fuse box lives and there at the side of the fuse box lives the release tool
    On the front cross member above the interior mirror there is a square plastic blank
    flick the blank out and insert the tool until the cog engages the motor and turn the red part of the tool handle to engage the tool into the motor
    turn the tool anti clockwise to release the top locks and the roof will pop up a bit
    Remove the tool and get a second person to lift the roof slowly from the opposite side of the vehicle until front section of the roof is pointing upwards and at the same time lift the rear part of the roof up.
    Second person hold the roof in this position and pop the rear seat centre section out
    The tool is needed again and it locates inside the ski hatch facing upwards
    push the tool upwards again until you locate the motor and repeat the process for the front lock
    the roof box will pop up and you need to lift the lid upright and slowly allow the roof to collapse into the storage box
    close the lid and lock the motor with the tool then unlock the motor
    lift the lid and lift the roof slowly until the front section is pointing at the sky and then shut the lid down and lock the motor
    Allow the front section to drop into the front locks and lock the motor
    the roof has been opened and closed so the lock micro switches should have reset.
    Turn the engine on and open the roof fully then close it fully and that's should do it
    if the operation is still faulty then there is a fault
    Jul 2013
    ignition off
    Thank you for your replies,I think I did all of that yesterday with the help of passers byers, BUT will try again tomorrow when I can get more help.
    I do hope it is as simple as that! Fingers crossed.
  1. Motul RBF600 brake fluid 500 ml bottles for sale, £10 posted
    By devonmikeyboy in forum For Sale/Wanted - Audi Parts
    Last Post: 27th March 2012, 12:24
  2. steering rack leaking hydrolic fluid
    By deburgh999 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th September 2011, 14:26
  3. Help - where is the power steering fluid bottle !
    By GT130 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th February 2008, 20:33
  4. location of Santa Pod meet
    By RussellFord in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd July 2003, 12:36
  5. Brake Fluid
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2003, 23:39
