Badger5EM Tuning
Results 1 to 8 of 8
    Sep 2009
    102
    Muti Function Steering Wiring Broken! and Airbag Fault .. Help!!
    Hi,
    I have a 3 spoke multiple function steering wheel. Was doing a DIY DIS/Cruise control mod today and accidentally snapped the wire on the steering (the connector and wire is now separate). Is there anyway i can get a replacement part or do i need to purchase the whole steering wheel? Also is this the cause of my airbag fault code (below)? Thanks!!
    2 Faults Found:
    00588 - Airbag Igniter; Driver Side (N95)
    001 - Upper Limit Exceeded - MIL ON
    Freeze Frame:
    Fault Status: 11100001
    Fault Priority: 1
    Fault Frequency: 1
    Mileage: 1048575 km
    Time Indication: 0
    01587 - Igniter 2 for Airbag; Drivers Side (N250)
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Mileage: 1048575 km
    Time Indication: 0
    Audi A4 2.0TFSI Quattro S-line - Stock! (for now)
    27,014
    Show us a pic of the damage before advisory on what to do next.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,098
    As Nigel has said, show us some pics.
    But I don't see how you "accidentally" broke the wiring
    I have a spare wheel with buttons and wiring intact if interested? Going cheap, just want it out the way.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Sep 2009
    102
    Sorry for the delay. Here is the pic.. I have sorted the Airbag faults. Turns out to be the loose yellow connector.
    I suspect the wire must have caught between the bolt and the airbag when tightening.. the problem is all three wires inside the 'bundle' are not labelled and are all the same color - black!
    Sep 2009
    102
    How much are you willing to sell the wheel? Is it an sline wheel?
    Quote Originally Posted by Dannykn9 View Post
    27,014
    Just repair the wires.
    Sep 2009
    102
    The problem is all three wires look the same so it will have to be a trial and error exercise. However, I am very scared to test it with the airbag not fully secured and battery connected... Any advice will be welcome!
    27,014
    You could always send it to me for repair.
  1. Replies: 14
    Last Post: 15th June 2011, 20:30
  2. Need help with pics of steering wheel and airbag
    By moogie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th July 2007, 21:28
  3. Parrot CK3000 and Multi-function steering wheel
    By Tipster in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th March 2007, 21:48
