Volks AutosAH Fabrications
    Def-87's Avatar
    B7 2.0 TFSI Quattro
    May 2013
    Suffolk
    46
    Post B7 Oil Filter Housing leak at bottom
    Right went to audi this morning to pick up service parts for servicing my a4 b7 2.0 tfsi quattro.
    Before i removed the oil filter housing i had noticed over past couple of weeks there was small leak coming from the bottom.
    This afternoon i have just replaced oil and oil filter with new seal. i have just checked and noticed that i am still loosing a small amount of oil from bottom of oil filter housing. i am predicting that the little seal at the bottom of the filter, which is on the orange part where the oil drain hose screws into has perished???
    Does anyone know if this is a replacable part of whether a new oil filter housing is required??
    Any help would be most appreciated!!!
    AUDI A4 B7 2.0 TFSI QUATTRO
    HID'S, CUSTOM DRL'S, LED INTERIOR LIGHTING, CRUISE CONTROL, BLUETOOTH
    Apr 2010
    346
    well mate,only had mine off today what i noticed is that the nipple where the oil comes out can be pushed back into the filter housing,i just pulled it back out with a long nose pliers till it snapped back into place might be worth checking this first
    Def-87's Avatar
    B7 2.0 TFSI Quattro
    May 2013
    Suffolk
    46
    im referring to this picture which shows number (1)
    its the orange nipple like with seal??
    also does anyone know if the protective cap in picture below (1) is replaceable with part numbers???
    Molnboman's Avatar
    Sorry, for going off the thread. I noticed mine seemed to be weeping last time I looked. Not sure if it is stuff left over from the last change. It can be very messy when you change the oil filter using this VAG design...The oil goes feckin everywhere. I also read somewhere else that there is a metal replacement fliter housing available ( non vag ) but not sure who supplies it.
    A
  1. Oil leak from the oil filter housing.
    By RobMorris in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th March 2013, 12:45
  2. HELP oil leak ?? 98 agu 1.8t ???oil filter housing or oil cooler??
    By ScottScodude30 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2012, 15:41
  3. Oil filter housing breather hose question-BOOST LEAK?
    By Scullies in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th March 2012, 19:52
  4. 1.8T Part needed, Oil filter housing
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th July 2010, 13:40
  5. oil filter housing valve
    By treblesykes in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th March 2007, 21:39
