Chris NottSky Insurance
    Jun 2013
    air intake manifold, actuator and flap
    Hi for the past few months I have been experiencing intermittent limp mode with flashing glow plug and also lack of power without any alarms.
    Turning ignition off and on clears problem until next random time
    Car spent a few days in Audi and they were unable to replicate fault or diagnose without an alarm.
    I managed to get it in again with alarm showing and after a few days I was given a quote of £1200 to have "air intake manifold actuator and flap " replaced
    Also advised to have egr cooler replaced at a cost of £600
    my question is what is this part ( air intake manifold ) and is the price excessive ( I have since taken the car back without any work done)
    car is a 2007 2.0 TDI 170 s-line
    thanks
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,520
    welcome
    Jun 2013
    Thanks bez
    the old one's Avatar
    Nov 2008
    The TOON
    27
    had this happen for a while now on my 1-9 a4 and it went after thrashing it for a good few miles but has started doing it again,i think its all the slow running causing soot !!!!
    Mar 2011
    North Wales
    210
    Did you get a fault code ?
    If it is the vacuum actuator on the inlet manifold they are fairly easy to replace and only cost about twenty quid with gasgets.
    Jun 2013
    To follow on from this story - a few days after getting the car back from Audi ( untouched ) the dpf light also came on and no matter how hard I tried I could not clear it. Took the car to an independent garage and had the dpf and egr deleted. The car feels better than ever so touch wood no more boost issues
  1. Inlet manifold.. Porting and R32 TB.......
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th March 2011, 18:19
  2. Taking the risk and retrofitting BOSE after other upgrades has anyone done it?
    By Troubs12 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th April 2010, 10:20
  3. Hitlers take on FOTA and the F1 Series
    By *Unkle* in forum You Tube Links
    Last Post: 28th June 2009, 12:24
  4. S3 turbo, manifold, injectors and Gen4 Haldex Rear Diff for sale
    By pontias_s3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th June 2009, 22:09
  5. Replies: 10
    Last Post: 3rd May 2005, 18:37
