hi all ,i replaced my washer bottle that doesn't have a low level sensor,my question is can i join any of the wires to fool it so it thinks there is a sensor there until i get a new one.
I mean if you need to disable the washer warning because no sensor is fitted, you can connect a wire from the cluster to the chassis/ground & this will tell the car the sensor is fine & not warn you.
