Chris NottEM Tuning
Results 1 to 8 of 8
    Dec 2011
    47
    Thumbs up Help! A4 2.0Tdi S line...
    Just bought a late 2005 b7 a4 2.0tdi S line 140.
    Car drives very well, accelerates pretty good to.
    HOWEVER...
    1. When put into high gear and in low revs the car judders violently until about 2k revs and then just accelerates normally. When the car is in 6th gear at around 1200-1300 revs upon acceleration it shakes quite bad. This then stops at 2k revs and the car drives normally.
    2. At idle the car also shakes a little.
    I have had one of these before with an oil pump issue so know what thats like - my last one would shake and judder hard on acceleration no matter the position of rev counter. This car however is smooth high in the revs and will easily go over 80mph!
    What do you guys think it is? Quite worried.
    Any help much appreciated
    Thanks in Advance!
    Dec 2006
    N.Ireland
    369
    Flywheel judder?
    Apr 2010
    329
    does it make any difference when you press the clutch at idle
    Dec 2011
    47
    No difference when pressing clutch. No rattle or play from flywheel when cutting car out. Judder at low revs when accelerating. Friend thinks it may be injector harness?
    Conmase's Avatar
    Mar 2013
    I have the same problem and I have been told its injectors
    Jun 2011
    Great Melton Norfolk
    1,340
    Dont think the car will like being put into 6th at 1200 rpm,no wonder it judders.
    Dec 2011
    47
    I had the car put on diagnostic and comes up as misfire in cylinder 4. p0304 or something along those lines.
    Could this mean injector? or injector harness? Put into high gear at even 14-1500 revs the car shakes hard!
    Dec 2011
    47
    bump
  1. 05 Audi a4 2.0tdi s line, hard juddering at high revs. HELP PLEASE
    By vavavag in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 26th September 2012, 13:57
  2. my new 2.0TDI s-line is here
    By andyollie in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th January 2006, 21:30
  3. 1000 mile report 2.0TDi S-line Sportback
    By cosmicblue in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th November 2005, 17:38
  4. A3 sportback 2.0tdi S line DSG - When ???!!!
    By Amchlolor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th January 2005, 17:03
  5. New Audi A3 2.0TDI S Line
    By JasonM in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st April 2004, 09:15
