Chris NottEM Tuning
Results 1 to 11 of 11
    jbee3's Avatar
    May 2013
    50
    Revo Remap problem
    Hi there - a few weeks ago i had my 2004 A4 Avant 190 Quattro remapped with the Revo Stage 1. I'm no expert on these things but apparently it took my car from 190 to 225 bhp.
    I only use Shell V Power in the car (From a few weeks before the remap right until now).
    The first few weeks the car was totally transformed. Especially in second, third and fifth gear i noticed a massive difference in the powerband. In second and third acceleration was addictive and accompanied by a big whooshing sound.
    I was really enjoying a new lease of life for what is quite an old car really.
    However from Friday the car seems to have gone back to stock. When I floor it in second and third I do get the sort of whooshing sound but no surge in acceleration. The car also doesn't seem to be driving very smoothly and 'miles left' numbers have plumetted from 420 on a full tank to only 250!
    Any ideas??
    Justin
    Jan 2012
    1,837
    I take it you had a before and after rolling road run?
    Have you had it scanned for faults? Could be a split hose etc.
    jbee3's Avatar
    May 2013
    50
    Hi there - no I didn't get that done - was that something the dealer should have done?
    The car actually went in for a new aircon compressor at Russell Automotive. They gave the car a check over and found two oil leaking items which they replaced. They said they didn't touch the ECU and that it would not be affected.
    jbee3's Avatar
    May 2013
    50
    Quote Originally Posted by a6-chris View Post
    What is a split hose? Is it expensive to fix? Is there any way i can tell just by opening the bonnet? What should i look for?
    Apr 2010
    346
    what he means by a split hose is the pipes connecting to your intercoolers could be split cracked or broken etc,you can check by inspecting them for air leaks.
    Nov 2010
    Derby
    Sounds like your car is a B6 to me? ..
    In any case, as has been said already, get it scanned for faults... but I would already be looking towards the diverter valve.. the extra boost from the re-map could have split the rubber diaphragm.. it's such a common problem..
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,525
    if it was a B7 2.0 fsit id say DV
    so are you b6 b7 1.8 or 2,0 ?
    Nov 2004
    Tonbridge, Kent
    912
    If they disconnected the battery is there a chance it has reverted back to basic revo settings?
    deburgh999's Avatar
    Feb 2011
    64
    Getting my b7 1.8t remapped this week by revo, am I right saying if the battery is disconnected it loses the map in some shape or form?
    bez101's Avatar
    Jul 2008
    8,525
    you dont loose map with batt been removed
    Craig Cull's Avatar
    Oct 2011
    Leeds uk
    1,147
    Visit Craig Cull's Youtube Channel
    I used to run a Leon cupra r 1.8t 20v 225, yours is a similar engine apart from the internals. I would go straight to the stock diverter valve. You will find this connected to your intake pipe. The standard diverter can in no way take a re map. Under high boost it simply blows open and stays open, hence the whooshing sound. The best replacement for this is a forge 007p or in my case I went for the forge splitter r as it is fully adjustable. About of a pain to set up, but in the end it will be way more responsive. I would still have it plugged in to check that I'm right. But from past experience, I would start and probably end with the diverter
    K04 hybrid turbo. S3 injectors, Autotech hpfp internals, RS4 fuel pressure regulator, custom FMIC, APR carbonio intake, decat pipe, milltek cat back non resonated 100mm tips, unicorn developments custom remap, launch control and flat shift. Valet mode, economy map and full power map options. Stage 3 southbend clutch with single mass flywheel, Eibach pro street coilovers, eibach front and rear anti roll bars, porsche cayenne 6 pot calipers front, S4 rear brake conversion.
  1. A3 2.0T Revo Remap Group Buy. 10% Off @ ADS In Preston, See Below
    By DaveS3Turbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th December 2005, 09:07
  2. Revo remap on 2.0TFSI DSG!
    By miketweed in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th December 2005, 09:04
  3. Revo remap on 2.0Tdi DSG
    By mikep in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th December 2005, 15:04
  4. Revo remap for AUDI S3 how much?
    By imported_ashs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th May 2005, 19:39
  5. APR chip or Revo remap for A4 1.9tdi? Which one?
    By oneniner in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th November 2004, 20:56
