Volks AutosChris Nott
    May 2013
    20
    When did they update from diaphragm to Rev D valve?
    Thinking about getting my 57 plate 2.0 TFSi remapped. Keep reading posts about the old DV not being up to it. But unsure if I have the new modded type or not?
    27,075
    Check the part number.
    Nov 2010
    Derby
    Took mine off my 05 plate Tfsi yesterday and this is what I found.. It was a rev B and as you can see, splits in the rubber all around it.. picked up a rev D from TPS (06H145710D) for £44, takes 20 mins to fit.. it's like a different car.. ! On an 07 plate like yours, I would definitely check.. It makes a big difference...
    ben.w93's Avatar
    Sep 2010
    Devon/Cardiff
    213
    I agree with arch, easy to check, more than likely to have a rip in it in a car of that age, mine made so much difference, was always disappointed with the performance until I replaced my ripped valve.
    2008 A5 3.0TDI
  1. Rev D DV Valve When did this come out?
    By jaydav2306 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th August 2012, 11:39
  2. When did sidelight bulbs change from bayonet style to 501's?
    By au_sjo in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th February 2012, 14:28
  3. When did the 8P receive it's various updates?
    By davoaj in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th February 2012, 14:44
  4. Where did they come from?
    By unkle in forum Site Support & Announcements
    Last Post: 16th January 2007, 00:13
  5. When did the S3 face lift happen?
    By imported_Wicked666 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2005, 17:48
