Bluetooth RSNE Plus Issues with Samsung S4
V6 Quatt
NULL
Hope someone can help.
I recently upgrade to a Samsung Galaxy S4 4G - and have managed to sync to my OEM RSNE plus.
It connects fine and works as it should. But when a call has ended either way it does not automatically revert back to CD / Radio and there is pure silence. The only way I have found to eliminate this is when a call has finished quickly press the "End Call" button at this point the radio or CD comes back on!!
Is there out there that knows how to fix this.
Thanks in advance
Thanks for your reply NHN Not Sure
How would I find out
Oh I will have to get it checked and come back you.
Any ideas what the cause may be??
Remove all pairs, reset both systems, re-pair & allow contact integration & test, if its older module, it may not like the module & therefore need upgrading.
Tried to re pair and refresh settings etc. but still the same.
Could always try pairing with a car in dealership :)
When your call finishes, you mean you use the mfsw end call button or you expect it to drop out automatically everytime when other party has hung up from you?
