EM TuningVolks Autos
Results 1 to 12 of 12
    Apr 2013
    25
    Airbag light keeps coming on
    Hell all.
    Ive had a problem with my airbag light ever since ive owned my S4. Its been back to Audi twice (for 5 days then 9 days) and they have replaced seat belt tensioners, airbags, wiring and an airbag controller.
    The airbag light has come on again and shows up this error on VagCom:
    Address 15: Airbags Labels: 8H0-959-655-94.lbl
    Control Module Part Number: 8H0 959 655 E HW: 8H0 959 655 E
    Component and/or Version: Airbag 9.42 H11 1840
    Software Coding: 0071114
    Work Shop Code: WSC 00097 210 87219
    VCID: 3C7D45547F70B8E
    1 Fault Found:
    01762 - Solenoid for Roll-Over Protection; Pass. Side (N310)
    001 - Upper Limit Exceeded - MIL ON
    Can anyone tell me what this error is please? And what i shoudl do.
    Thanks for your time.
    Warren
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,536
    is it a cab ?
    Apr 2013
    25
    Missed that bit of (important) info - yes it is.
    bez101's Avatar
    Jul 2008
    8,536
    its pointing to the modual that runs the antiroll
    the 2 things behind the head rests
    they pop up if the car rolls
    Apr 2013
    25
    Thanks Bez101, i guessed it was from the error message - the passenger side one.
    Is it a replaceable part do you know?
    W
    bez101's Avatar
    Jul 2008
    8,536
    it should be.
    no idea where it is tho
    27,129
    It is, but hopefully you're sitting in one of those back seats, it shows as about £700 each as there's 2, but I would check wiring to it 1st as that error comes up for when you disconnect wheel bags & seats, so maybe simple fix.
    The part is built into the pop up part, so you need to look through the boot or remove back seats, which in itself is a pita to get headrests of.
    Apr 2013
    25
    Thanks NHN (for both forums), i appreciate your time.
    Looks like i have to remove the rear seats and take a look then. Audi have done extensive work on my car around this problem so i wonder if they haven't plugged it back in properly.
    Its just the rear headrest restraints that look to be an issue - ill read up on that.
    Do you have the part number for the solenoid please.
    W
    Apr 2013
    25
    Hello all
    Does anyone have instructions on how to remove the rear seats on a B7 A4 Cabrio please?
    W
    bez101's Avatar
    Jul 2008
    8,536
    its a PITA to remove
    google my have a how to
    27,129
    Couldn't agree more, real pita to get those plastic tabs out of the way to lift them of & out.
    Apr 2013
    25
    Your not joking - spent about 2 hours trying to work out how on earth the headrests come off - how do they come off?
    Whoever designed that wants sacking.
  1. Yellow airbag connector under seat causing airbag light to come on
    By pj123 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th December 2012, 18:46
  2. abs light and esp light keeps coming on help please
    By madmark in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2010, 19:50
  3. Airbag Light! Just come on....grrr
    By Hardsy in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th October 2007, 13:09
  4. boot/door warning light keeps coming on for no reason
    By deanosavanna in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th July 2007, 19:44
  5. Airbag light has come on - help?
    By coajt in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd August 2005, 07:44
