Sky InsuranceEM Tuning
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By NHN
Thread: Steering angle, ESP issue after Cruise control install. PLEASE HELP :)
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    728
    Right, just spent the morning installing new steering wheel, dis and cruise. The parts i used are (all secondhand):
    Dis stalk 4e0953503c
    Cruise stalk 4e0953521
    Steering ecu 8e0953549q
    Mf wheel 8e0419091 ee vdu
    Slip ring 4E0953541A
    Ive got Dis and the radio controls working. However ive killed my parrot handsfree (doesnt power on) and cruise isnt working.
    The ESP light is stuck on. And i cant seem to set the steering angle sensor??? ABS coding II/login is grey.
    Have added cruise on engine coding to 010C0003180F0118 from 010C0003180F0018 which i assume is correct. I used my previous ABS code. Ive looked on Ross-tech and several other sites but cant seem to get my head round it
    Original scan:
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E26A144747 Mileage: 149430km/92851miles
    Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
    Part No SW: 8E0 910 559 Q HW: 8E0 907 559
    Component: 3.2l V6 FSI 0020
    Revision: --H16--- Serial number:
    Coding: 010C0003180F0018
    Shop #: WSC 06325 000 00000
    VCID: 3B7378807A6DC4C0359
    2 Faults Found:
    004440 - Manifold Pressure Sensor (G71)
    P1158 - 007 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 29
    Mileage: 149190 km
    Time Indication: 0
    Freeze Frame:
    RPM: 704 /min
    Mass Air / Rev.: 98.1 mg/str
    Temperature: 94.5°C
    Idle
    Voltage: 14.28 V
    Speed: 0.0 km/h
    000104 - MAP/MAF <-> Throttle Position Correlation
    P0068 - 006 - - Intermittent
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 29
    Mileage: 149190 km
    Time Indication: 0
    Freeze Frame:
    RPM: 704 /min
    Temperature: 94.5°C
    Idle
    Voltage: 14.18 V
    Bin. Bits: 00000010
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 8E0-910-517.lbl
    Part No SW: 8E0 910 517 E HW: 8E0 614 517 AL
    Component: ESP8 quattro H05 0120
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004379
    VCID: 295FB2C880F14650575
    No fault code found.
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 BL
    Component: A4 Klimaautomat 2832
    Coding: 00000
    Shop #: WSC 00000
    VCID: 6CD18BDC1C839378EC3
    Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
    Part No: 8E0 907 279 L
    Component: int. Lastmodul ECE 0504
    Coding: 10021
    Shop #: WSC 06325
    VCID: 3B737880296DC4C0359
    Address 15: Airbags Labels: 8E0-959-655-94.lbl
    Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
    Component: Airbag 9.41 H11 3530
    Revision: 91H1135 Serial number: 0036M008HPNI
    Coding: 0034622
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 S
    Component: Lenksáulenmodul 0611
    Coding: 01002
    Shop #: WSC 06325
    VCID: 43830060519DBC007D9
    Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
    Part No SW: 8E0 920 951 F HW: 8E0 920 951 F
    Component: KOMBI+WFS 4 H12 0110
    Revision: 0110 Serial number: 00000000000000
    Coding: 0023401
    Shop #: WSC 00654 512 00000
    VCID: 2D5746D8B7195A70BBD
    New Scan:
    Sunday,16,June,2013,16:24:59:02148
    VCDS Version: Release 11.11.6 (x64)
    Data version: 20121223
    69 75 76 77
    Coding: 010C0003180F0118
    Shop #: WSC 06325 123 12345
    1 Fault Found:
    005497 - Throttle Actuator (J338)
    P1579 - 008 - Adaptation Not Started - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 149439 km
    Time Indication: 0
    Freeze Frame:
    Load: 12.9 %
    Load: 87.8 %
    Temperature: 96.0°C
    Temperature: 63.0°C
    Voltage: 13.57 V
    Speed: 0.0 km/h
    Readiness: 0110 0001
    Coding: 0004379
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 40
    Time Indication: 0
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x4222
    Hex Value: 0x001E
    Hex Value: 0x3EA7
    Hex Value: 0x0001
    Coding: 00000
    Shop #: WSC 00000
    Coding: 10021
    Shop #: WSC 06325
    Coding: 0034622
    Part No: 8E0 953 549 Q
    Component: Lenksáulenmodul 0601
    Coding: 02042
    Shop #: WSC 06335
    VCID: 418F0A684B81AE106F5
    1 Fault Found:
    01794 - Control Module - Incorrect Chassis (VIN) Number
    35-00 - -
    Coding: 0023401
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0804
    Coding: 00001
    Shop #: WSC 00000
    VCID: EBD308C0998D1440659
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 CA
    Component: Komfortgerát T3B 3332
    Coding: 08187
    Shop #: WSC 06325
    VCID: 72ED95A43EA7458826F
    Subsystem 1 - Part No: 8E2959802F
    Component: Tõrsteuer.FS BRM 0506
    Subsystem 2 - Part No: 8E2959801B
    Component: Tõrsteuer.BF BRM 0205
    Subsystem 3 - Part No: 8E0959801E
    Component: Tõrsteuer.HL BRM 0606
    Subsystem 4 - Part No: 8E0959802E
    Component: Tõrsteuer.HR BRM 0606
    2 Faults Found:
    01134 - Alarm Horn (H12)
    37-10 - Faulty - Intermittent
    00955 - Key 1
    35-10 - - - Intermittent
    Address 55: Xenon Range Labels: 4F0-910-357.lbl
    Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
    Component: AFS 1 H01 0010
    Revision: 00000001 Serial number:
    Coding: 0000019
    VCID: 2859B7CC9BFB7F5848B
    Part No: 8E0 941 329
    Component: AFS-Modul links H03 0020
    Component: AFS-Modul rechtsH03 0020
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 195 M
    Component: symphony II PM6 0460
    Coding: 01425
    Shop #: WSC 66048
    VCID: 316F5AA8FB213E909F5
    1 Fault Found:
    01303 - Telephone Transceiver (R36)
    49-00 - No Communications
    Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
    Part No SW: 8E0 919 283 D HW: 8E0 919 283 D
    Component: Parkhilfe 4-Kan H06 0010
    Revision: 00H06000 Serial number: 00067802020530
    Coding: 0000114
    VCID: 316F5AA8AB213E909F5
    Hoping someone can point me in the right direction. Driving to Scotland next weekend and really want the ESP/ABS working for that
    Thank you
    Barry
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    Jan 2012
    1,837
    Do a full lock to lock on the wheel and go for a short drive. It should clear it.
    rizzini7's Avatar
    Jun 2011
    728
    Quote Originally Posted by a6-chris View Post
    Didn't earlier. But, I'll try in the morning when I go to work. Assume it doesn't need plugging into vagcom for this??? Must remember I have no abs when braking
    rizzini7's Avatar
    Jun 2011
    728
    Do you have to be moving when doing the reset? As some threads say you do and others don't? Fingers crossed that works. If not where do I need to be looking next
    27,099
    Yes you do need to drive to get lights to go out & steering to reset so not heavy.
    Do a vin learn on the steering module 1st, then try & calibrate the steering sensor when the module 16 error has gone.
    Audi A4 (8E) Steering Wheel - Ross-Tech Wiki
    rizzini7's Avatar
    Jun 2011
    728
    Thanks Nigel, so I just enter 00111. Wait till its done what it wants then recode for the dis etc..? Thanks again
    Strangely the steering didn't feel that heavy? Will see how it feels when I now to to work as I haven't got time to code this morning
    27,099
    Yes theoretically it should be that simple
    rizzini7's Avatar
    Jun 2011
    728
    Well think ive got it thanks, will take it out for a drive in a while and clear the codes. Most recent scan after setting steering. Assume the control module faults are from resetting the module?
    Monday,17,June,2013,19:22:53:02148
    69 75 76 77
    VIN: WAUZZZ8E26A144747 Mileage: 149460km/92870miles
    1 Fault Found:
    005650 - Engine Control Module Incorrectly Coded
    P1612 - 008 -
    Freeze Frame:
    Fault Status: 01001000
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 149463 km
    Time Indication: 0
    Freeze Frame:
    RPM: 704 /min
    Mass Air / Rev.: 92.7 mg/str
    Temperature: 94.5°C
    Idle
    Load: 14.1 %
    Speed: 0.0 km/h
    Readiness: 0010 0001
    Coding: 0004379
    Shop #: WSC 12345 000 00000
    Coding: 00000
    Shop #: WSC 00000
    Coding: 10021
    Shop #: WSC 06325
    1 Fault Found:
    01326 - Control Module for Multi-Function Steering Wheel (J453)
    49-10 - No Communications - Intermittent
    Coding: 0034622
    Coding: 02042
    Shop #: WSC 06335
    Coding: 0023401
    Coding: 00001
    Shop #: WSC 00000
    Coding: 08187
    Shop #: WSC 06325
    3 Faults Found:
    00955 - Key 1
    00466 - Control Module for Steering Column Electronics (J527)
    Coding: 0000019
    Coding: 01605
    Shop #: WSC 66048
    Coding: 0000114
    1 Fault Found:
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 4
    Fault Frequency: 3
    Reset counter: 167
    Time Indication: 0
    27,099
    Clear the faults 1st, then scan again & see what's left, if clear then test the cruise stalk in measuring blocks of the steering module 16, to see if it can see the stalk positions.
    rizzini7 likes this.
    rizzini7's Avatar
    Jun 2011
    728
    Will do today hopefully if not will have to be tomorrow. Will keep updated. Thanks for the help Nigel
    rizzini7's Avatar
    Jun 2011
    728
    Well, abs, esp, dis and cruise is working. Last scan didn't save but im sure it was fault free i forgot to fully check. Will run another before going away to be on the safe side. Thanks again mate
  1. Replies: 7
    Last Post: 27th March 2011, 07:40
  2. A4 B6 Cruise Control Install & Meet Weekend
    By jb0o in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th March 2011, 08:46
  3. A4 B7 Cruise Control Install & Meet Weekend
    By jb0o in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th March 2011, 16:10
  4. climate control issues after rns-e install
    By B6 ESSEX in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th June 2010, 19:53
  5. Cruise Control Install
    By mattp in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th July 2006, 13:32
