EM TuningChris Nott
    Dec 2012
    Birmingham
    227
    Problem with 7 speed multitronic gearbox
    I drove my car to work earlier today, and when I finished I come to the car and started it, foot on brake and the light on by the gearstick went off as normal but when I pushed the button in to select drive it wouldn't shift.
    Havn't had this problem before, has any one else experienced it and is it a gearbox problem or the gearstick area?
    thanks!
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,935
    try a scan may be a fault code stored
    26,762
    Sounds like the lock isn't disengaging when in park, I would do a check with vcds measuring blocks to see if its got a dodgy lock, may be able to adjust or replace, speculative over the net, but if the lever isn't moving, then it would be my 1st thing to check.
  1. Transmission problem with A4 multitronic
    By Chunkymonkey in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st September 2011, 12:42
  2. Problems with A4 Multitronic Gearbox
    By purplecatqueen in forum General Technical / How To
    Last Post: 18th May 2009, 15:35
  3. BIG problem with DSG Gearbox
    By Wolfie in forum TT/TT-S/TT-RS Forum
    Last Post: 22nd December 2008, 11:33
  4. Problem with tiptronic gearbox
    By sandyjsmith in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th May 2006, 05:14
  5. a problem with gearboxs
    By a3kid in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th January 2005, 22:55
