Monster MotorsportVolks Autos
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By jdp1962
Thread: Anyone fitted a DIY tyre pressure monitor?
    Dec 2011
    145
    Since i have a poverty spec SE B7, thinking of getting this DIY TPM as it only takes a few minutes to install. Just wondering has anyone fitted such a TPM and are you happy with it? Its on sale at the moment at £70.
    2005 Audi A4 2.0 TDi SE
    oem bi-xenons with AFS & autolevelling
    oem balance shaft replacement
    oem rear parking sensors
    oem auto-dimming rear view mirror
    Shark STS Remap 170 bhp
    18" S5 style alloys
    H&R lowering springs
    TP-70 DIY Tyre Pressure Monitoring System
    Dec 2011
    145
    Ok took the plunge and bought it. Overall very happy with it, an absolute doddle to install and the display unit plugs in neatly into the cigarette lighter socket. Whilst driving the display scrolls showing the tyre pressure in psi. The only downside is that the wheel cap sensors (black) are a bit bulky but i don't find them too obtrusive. Will post some pics later on
    18" S5 style alloys
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,429
    yeah id like to see how they look
    iv retrofitted oem tpms in the past
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,664
    So, how does this work? Do the monitor caps send information to the display wirelessly?
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Dec 2011
    145
    Quote Originally Posted by jdp1962 View Post
    Yep, the sensors (built into caps) transmit wirelessly to the display...i believe the frequency used is something like 433 mhz. The sensors take a replaceable battery (CR2032?) which is supposed to last 3-4 years. Just hope the local chavs don't pull off the sensors because even though they're fitted with locking nuts, i'm sure with a bit of force they can be pulled off
    18" S5 style alloys
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,664
    I'm fancying a set of these.
    marky67's Avatar
    Feb 2011
    Solihull
    56
    Do you need to get your wheels re-balanced.... 'cause they look a bit bulky?
    A4 2.0 TDi 170 Quattro S Line
    Phantom Black
    Dec 2011
    145
    Some pics
    18" S5 style alloys
    Def-87's Avatar
    B7 2.0 TFSI Quattro
    May 2013
    Suffolk
    46
    Im very interested in these. Could you send me the website where you brought them??
    AUDI A4 B7 2.0 TFSI QUATTRO
    HID'S, CUSTOM DRL'S, LED INTERIOR LIGHTING, CRUISE CONTROL, BLUETOOTH
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,664
    Quote Originally Posted by Def-87 View Post
    Click on the word "this" in the opening post.
    Dec 2011
    145
    Link's already in first post but here it is again:
    18" S5 style alloys
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,664
    Quote Originally Posted by psychopomp1 View Post
    I ordered mine yesterday; they're on their way. Nice find, Psychopomp.
    psychopomp1 likes this.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,664
    Arrived today, and were fitted and up and running inside ten minutes. Unfortunately, I only checked the display after I'd tightened all the lock nuts, and that's when I noticed the front right is reading 36psi when all the others are reading 37 (I wouldn't mind but I checked all of them with my compressor before fitting the TPMS sensors).
    It's now raining, so I can't be bothered to un-loosen the sensor and add some air to the tyre. It can keep.
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    720
    I'm quite tempted with the oem style ones that fit the rim. Has anyone tried them?
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,664
    Tweaked the pressures again, and I now have a reading of 37psi all round on the Steelmate monitor display - which, incidentally, corresponds to 38psi on the display of my compressor. The discrepancy doesn't really matter, so long as I know it's there. The point is that the tyres are at the pressures I like them at.
  1. Tyre pressure monitoring???
    By killa_z in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd February 2014, 10:52
  2. MY11 8P with Tyre Pressure Monitor Anyone?
    By NHN in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th November 2010, 13:25
  3. Tyre Pressure Monitoring Kit
    By Sirus in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th February 2008, 22:12
  4. to those who have the tyre pressure monitoring system (TPMS) ?
    Last Post: 24th December 2007, 00:58
  5. Tyre pressure monitoring
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th May 2007, 13:07
