    ESD1711's Avatar
    Mar 2013
    Edinburgh
    500
    Follow ESD1711 On Twitter Visit ESD1711's Instagram Channel
    Which size brakes?
    Morning B7 folks.....
    I'm gonna look to do the front brakes on my car in the next couple of weeks. Have toyed with the idea of going down the upgrade route, but given the way the car is used - I cant really justify it at the moment...... so, I'll just be replacing them with like for like.
    However, when I've gone to start looking, i'm finding there's an array of different diameter discs quoted.... 280mm, 288mm, 312mm etc. Not sure if this is maybe sline vs non sline? Or 140 vs 170?
    So my question is, which is the correct size for my car?!
    For info, the cars a 2006 Sline Avant, 2.0 TDi, and the 140bhp model.
    Beyond that - any recommendations with regards to whats good or what to steer clear of? Note that I have no need or desire for high end brakes just now - cheap and cheerful is very much fine for what I need at the moment
    Cheers,
    Erik
    Sep 2010
    Telford/Shropshire
    367
    The best thing you can do is take a wheel off , measure Your current discs,and get them replaced.
    + you can go for is some fresh good brake fluid,or if you willing to spend then steel braided brake lines.
    Proud owner of a:
    2.0T FSI quattro A4 S-line (saloon)
    Build thread
    http://www.audi-sport.net/vb/audi-s4-a4-a4-cab-b7-chassis/192911-just-another-build-thread.html
    Molnboman's Avatar
    Good question?....sorry I can't answer but your local friendly parts supplier with a VAG parts system or VAG dealer should, if you provide them with your chassis number. On my car's vintage there were two different brake calipers used....so you have to make sure you get the right discs and pads to suit. As for discs I changed my 320mm or 321mm depending on who you ask.... using Mintex discs and Brembo pads less than 12 months ago and the fronts discs are warped already after only 35,000kms!.....Just bought Zimmerman discs and pads this time round to see if they make a difference. I have heard good things mentioned about Zimmerman and EMTEC discs using Green Stuff Pads....but never tried them myself. I notice on the forum that there are members who have had several issues with original VAG discs warping and had them changed under warranty. On the subject of brake hoses....I was warned to stay away from them up here ( Sweden ) as they can corrode quickly here during the winter months and can cause serious falure issues.....may not be the same back in the Old Country am sure.
    Good Luck
    A
  1. Which size brakes?
    By Ash187 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th April 2011, 11:23
  2. Which size BBS for S3
    By mattex in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th September 2009, 22:14
  3. Which Porsche Brakes?
    By charlieboy1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2009, 21:05
  4. Which front brake pads do people use? (standard S3)
    By James333 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st March 2008, 22:23
  5. Correct size brake discs for A3 TDI
    By f13ldy in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th April 2005, 13:34
