B7Gav
I collected this from the dealers at the weekend and had a bash at fitting it
so no cruise
1st
disconnect the battery then
put steering wheel to these positions and remove the 2 grommets at the back reviling 2 torx screws undo them and it removes the air bag
Unclip wires from the back
Undo the steering bolt that holds the wheel on make sure the steering wheel is straight and take the keys out of the ignition to lock the steering. The steering will be marked as can see from picture so just in case you forget where it goes
Then you need undo two torx screws holding the cowling on then the two Allen screws too
then remove the cowling
This is where it locates
Unclip the plug and the 3 clips then the squib comes forward be careful not to move this keep it how it it
Then pull the stalk forwards and clip in the cruise control switch then clip it back on the colume
so no cruise
1st
