Chris NottMonster Motorsport
Thread: Turbo Wastegate
    Mar 2012
    North Wales
    117
    Turbo Wastegate
    Hi all. It seems that the wastegate on my 2.0 tfsi turbo is loose possibly broken/worn out.. It is the 220 bhp bul engine type..Do I need a new turbo? or can it be a simple quick fix??The symptoms are a very distinct rattle when I lift off the throttle ? My local garage have kindly given it a once over and seem to think the rattle comes from the wastegate on the turbo manifold..Any helpfulll advice would be deeply appreciated..
    Missed gear
    Jan 2006
    Kent
    386
    There is some guidance here that may help.
    B7 A4 Avant S-line Special Edition v2 2.0 TFSi - AmD stage 1 - 263Bhp 396Nm
    Mar 2012
    North Wales
    117
    Thanks for the reply Stringster.I had a good read of that post and I don,t think it helps me much..I really think the wastegate on my turbo is on it,s way out and the only solution is to get rid of the car before it develops further.Don,t want to spend upto £1,000 on replacing turbo on an 7 year old car
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,295
    If it's same as the turbo off the Audi TT, VW Golf, Skoda, Audi A3, etc there's a fair few on eBay for less than three hundred, either way don't get rid.
    Mar 2012
    North Wales
    117
    Hi Dieseljake.I have been told that the turbo is the same as the 200bhp a4 TFSI,s...As I,m not that much of a mechanic I am forced to have the car done in a garage. With this cost and best part of £300 to buy a second hand turbo which might not be 100% I really can,t justify the spend..When my little boy starts school full time next year I will have some spare cash to buy a more upto date A4 but as for now I might be leaving the Audi scene for a while I will find out in the next couple of weeks..
  1. AUDI A3 KO3 TURBO EXTERNAL WASTEGATE
    By E4 FENN in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th April 2010, 09:11
  2. Turbo Wastegate "stuck"
    By Chrisavant in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th January 2010, 21:53
  3. Possible wastegate/turbo problem? Can you help?
    By A3 Sheltie in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2009, 23:47
  4. Logging turbo boost with VAG-COM
    By Ram in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th January 2009, 22:23
  5. TBCV (Turbo Boost Control Valve) and Wastegate
    By bham a3 in forum Diesel forum
    Last Post: 11th April 2008, 15:46
