Chris NottMonster Motorsport
    Dec 2011
    139
    Worth buying aluminium spigot rings?
    Hi,
    I've just received a set of 18" S5 style alloys for my B7 and since the CB is 66.6 on these wheels, there's a set of plastic spigot rings included to decrease the CB to 57.1. However just came across these aluminium rings on ebay, would they be significantly better than the plastic ones or is it not really worth splashing out extra for the aluminium ones?
    2005 Audi A4 2.0 TDi SE
    oem bi-xenons with AFS & autolevelling
    oem balance shaft replacement
    oem rear parking sensors
    oem auto-dimming rear view mirror
    Shark STS Remap 170 bhp
    18" S5 style alloys
    H&R lowering springs
    TP-70 DIY Tyre Pressure Monitoring System
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,413
    Not worth it really as all they do is make the wheel central to the hub, so they can be bolted down.
    Some come with alloy some come in plastic. Alloy versions can corrode over time as found on my OZs, otherwise I prefer plastic myself
    Mike
    Sep 2010
    Telford/Shropshire
    297
    no mate no worth really.
    as above the plastic ones will do the job. so don't waste money on something that won't make a real difference.
    2005silver A4 2.0T FSI quattro S-line (saloon)
    18'' alloys,RNS E,Silicone Tip,MTEC brakes,HEL steel braided brake lines,H&R springs (45mm)
    Build thread
    http://www.audi-sport.net/vb/audi-s4-a4-a4-cab-b7-chassis/192911-just-another-build-thread.html
  1. Are these discs and pads worth buying??
    By swatchuk in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2009, 20:24
  2. is it worth buying vagcom license?
    By Jonesy in forum VCDS (formerly VAG-COM) forum
    Last Post: 25th October 2006, 10:54
  3. VW Passat V5 2003 worth buying???
    By audi5e in forum General Chat
    Last Post: 15th February 2006, 15:31
  4. MOVED: IS VAG-COM WORTH BUYING
    By taj in forum TT/TT-S/TT-RS Forum
    Last Post: 27th August 2004, 11:18
