Sky InsuranceChris Nott
Results 1 to 8 of 8
Like Tree3Likes
  • 1 Post By jdp1962
  • 2 Post By GarJE
Thread: E-Con Smell
    May 2013
    20
    E-Con Smell
    When I run the E-con in low there's a urine smell. In A/C mode it's fine. I recently renewed the cabin filter for a carbon type. Any ideas?
    27,129
    It needs a aircon bomb to clean out the bacteria in the system, you can buy these at various places, try this 1st with aircon on full & the recirc button enabled or its pointless, as Jeff found out recently lol.
    Audi do offer a fumigate option, but try this 1st as they charge allot more.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,705
    Thank you for reminding everyone.
    NHN likes this.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    27,129
    I love you too :P
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,705
    Heheheh!
    On a serious note to Shaunos, the Comma aerosol cleaner is really excellent. Even if it doesn't fully cure the smell first time (which it probably will), treating it again with a second can will still be way cheaper than any dealer treatment. I also saved the cost of a new cabin filter by cleaning and re-using the existing one.
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    2,013
    I think mine cost around £26 at Audi when it was in for a service. The aircon bomb was on offer, but they forgot to list it on the works so I wasn't charged, though I did mention it.
    Had to clean the inside of the windows a few times afterwards though as it left a kind film on them.
    JSD 2.59
    Synergy-Solutions
    34
    Pull the glovebox off and you'll see a rubber plug on the side of the evaporator core.
    Direct a jet of water into that and catch the run-out from the floor vents with a towel.
    Best solution I've found to the smell.
    Lasts 3-4 years.
    sidibear and marky67 like this.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,705
    Oh, and last of all, if you want to get rid of the urine smell for good, stop peeing in the air vents.
  1. Air con smells
    By mm707 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th May 2011, 17:43
  2. Air Con Smell
    By Marc1 in forum Air Conditioning
    Last Post: 7th July 2010, 03:24
  3. Air con smells
    By Monsoon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th July 2008, 16:37
  4. Air con smelling funny after thermostat change
    By Jay in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th July 2008, 10:41
  5. Air con smell!
    By Marko in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th June 2006, 20:04
