Chris NottAH Fabrications
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By bez101
Thread: Centre brake light
    Jun 2013
    Centre brake light
    Hi all
    On a bit of a roll fixing things at the minute after VagPro saving the day. Anyway on my partners convertible the centre brake light works intermittently, any of you guys changed bulbs or cleaned contacts?
    Many thanks
    27,099
    It appears to be an led unit as no bulbs show in parts, so I would remove & check the connectors for corrosion, if its not this, then maybe split the unit & check the pcb, its about £45 part, but verify wirings all ok to the unit 1st.
    Abb
    Abb's Avatar
    Sep 2009
    Teesside UK
    322
    I had this problem about a year ago. Removed brake light, cleaned all connections etc, and it seemed to sort it.......for a very short time! You will be best off replacing the brake light, if I remember correctly, it was about £40, straight forward to do and I have never had any problems since.
    Audi S4 quattro cabriolet in dolphin grey metallic, Audi exclusive crimson red leather/black piping, red hood, carbon inlays, RNSE, tiptronic gearbox with paddleshift, electrically adjustable & heated seats, 6 disc multichanger, DVD multichanger, monitors in headrestraints, xenon headlights with power wash, cruise control, folding door mirrors, storage pack, 19" OE VW Touareg wheels with 25mm spacer/adapters all round, non res cat back quad tipped Milltek exhaust, lowered 30mm on H&R springs
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    as above but
    the cab has a prob with breaking wires
    so pull the rubber boots back and check for any damage,
    think that wire runs through the pass side rubber
    NHN likes this.
    27,099
    Don't know why I didn't think of that one, nice one bez obvious 1st place to look, doh.
    bez101's Avatar
    Jul 2008
    8,492
    only cos mine went last week
    ans the warning was bugging me all week.
    Jun 2013
    Hi guys,
    Many thanks for the advice will take a look hopefully over the weekend
    maikysupra's Avatar
    May 2013
    Oxfordshire
    110
    I had the same problem with my B7 Cabrio recently. The promblem was caused by dry solder joints in the LED unit. Easy fix if you have or can get hold of a solder iron. Let me know if you not sure how to do this!
    Jun 2013
    Hi, thanks for that still not had chance to take a look as stuck at work.
    Will let you know what I find
    bearder2006's Avatar
    Jun 2009
    205
    ive got the same problem now whats best to fix it please
  1. centre brake light warning
    By madphil in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd July 2010, 07:21
  2. Changing centre brake light on A4 Cabriolet
    By sva19 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 16th December 2009, 12:46
  3. Centre brake light bulb replacement
    By JohnC in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd December 2006, 21:54
  4. Centre Brake Light
    By cs_horn in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th July 2006, 18:29
  5. centre brake light access
    By MickA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd May 2005, 16:35
