Sky InsuranceBadger5
    Apr 2013
    A4, B7 Steering wheel problems
    Hi All,
    I am having trouble with
    I have had garage change over steering control module (correct for MFSW ad CC) and fitted 16 pin slip ring, as per detailed instructions on site have also reprogramed via VAG for cruise control and MFSW Cruise control is working super but Garage counldn't get the steering wheel controls to work. Part numbers for the airbag and steering wheels are:
    The steering wheel is 8P0 419 091 BG 1KT
    The Airbag is 8eo 880 201 ce
    have I been dumb and supplied the wrong steering wheel/bag. Comment from the garage were the connector for the Wheel did seem to be slightly different.
    Rob
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,454
    Hi Rob, welcome to audi-sport.net. Im sure one of the guys will advise you about part no. etc. have you any pica of the car for us? Where are you located? Enjoy the forum. x
    27,096
    Welcome to the site.
    It will be down to the wiring & coding in most circumstances & if the garage fitted the kit, they should be able to resolve it, if not then certainly we could, location dependent.
    Apr 2013
    Thank you NHN, I have contacted you before, I was the chap in Essex so it would be great to get you to have a look and maybe fit a radio at the same time.
    Rob
    P.s. I will post up some photos as soon as its clean and the steering wheel and Double din is in.
    27,096
    Aha I thought I recognised your name, ok I'll deal with email shortly sorry for delay.
  1. warning lights problem on a3 tdi 2009 with multi-function steering wheel
    By Alva78 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3 Days Ago, 15:11
  2. Problem coding new MFSW - Steering wheel angle error
    By JRock247 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th March 2013, 14:57
  3. Tiptronic steering wheel
    By TheTonsta in forum General Technical / How To
    Last Post: 31st August 2003, 18:57
  4. pc steering wheels
    By badbaz in forum Video Gaming
    Last Post: 10th August 2003, 14:33
  5. Steering Wheel Remtoe for stereo?
    By AutoMatt in forum In-Car Entertainment
    Last Post: 8th August 2003, 08:07
