Volks AutosSky Insurance
    May 2013
    16
    Black flexi pipe by cabin filter?
    Changed the cabin filter on my A4 at the weekend found a black flexi pipe (like tiny kopex). It has a oval shape plastic washer glued on the end. What's this pipe for?
    marky67's Avatar
    Feb 2011
    Solihull
    56
    I assume it's a breather pipe for the battery.... as that's where mine is attached.
    A4 2.0 TDi 170 Quattro S Line
    Phantom Black
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,314
    I agrew with Marky. On mine, the pipe comes from a little hole on the side of the battery, and disappears down the side of the cabin filter housing.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs.
  1. downpipe/flexi pipe
    By ian52 in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th October 2009, 20:24
  2. Wanted: audi a4 b5 braided flexy pipes to fit Brembo calipers
    By adamss24 in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th September 2009, 12:45
  3. CAT / Flexi-pipe
    By QuottroA4 in forum Tuning
    Last Post: 2nd August 2009, 10:26
  4. Cat / flexi-pipe
    By QuottroA4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st July 2009, 22:37
  5. Exhaust front flexi pipe
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2005, 23:57
