AH FabricationsChris Nott
Results 1 to 15 of 15
Thread: Sidelight issue
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    723
    Sidelight issue
    Right to start off I'm not very mechanically minded!!!
    My rear drivers sidelight (one on car, not boot?) started off pulsating then died altogether. (Engine running and off)
    Now passenger front sidelight bulb is out as well. I have just changed the rear bulbs and they work on and off (put new bulbs in and didn't work, until I started car?) Don't seem to flicker when engines running but pulse a little when engine is off. I'm assume this could be a current issue? Where do I start? Obviously the front bulb needs changing. Bumper off headlight out job .
    Sorry for my rubbish description. Thanks for any help in advance
    P.s passenger rear and driver front are fine
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    Molnboman's Avatar
    Can't help you with pulsating brake light issue, but you DON'T need to remove the bumper to do your side lights Matey....they are a headf&ck but doable from the engine bay access so av been told. You will need to remove the airbox if it's the offside bulb that needs changing. Check the changing bulb thread ...there's plenty of advice from crazed Forum members who have done it.....
    BTW....Wouldn't be an alternator issue would it?
    A
    rizzini7's Avatar
    Jun 2011
    723
    Brake lights are fine also, front is passenger l/h side (washer side). Also I've got the adaptive xenons and a v6 lump so no hands going in there I had a little try earlier and couldn't see the bulb let alone get to it.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,472
    leave bumper on
    get someone with small hands
    and just pull the fukker as hard as you can to pop it out
    rizzini7's Avatar
    Jun 2011
    723
    Don't think it's possible to get to but I'll have another look tomorrow. Just managed to undo cover earlier but couldn't see bulb or get my hand in there as the light unit is so deep. I didn't want to go messing near all the cables to much. Any ideas on pulsating guys? Cheers
    rizzini7's Avatar
    Jun 2011
    723
    Front bulb changed and working. The rear is still hit and miss. But, the brake light works fine. So I'm guessing earth or power issue. So, where's the best place to start looking
    ESD1711's Avatar
    Mar 2013
    Edinburgh
    498
    Follow ESD1711 On Twitter Visit ESD1711's Instagram Channel
    Was about to say it might be down to the bulb being in the wrong way, but not sure if that's even possible with the rears as I dunno what bulbs they are.
    Have had similar issues with front sidelights before that we're resolved by turning the bulb around though.
    rizzini7's Avatar
    Jun 2011
    723
    382's mate. I'll try it anyway
    ESD1711's Avatar
    Mar 2013
    Edinburgh
    498
    Ah probably unlikely then lol sorry
    rizzini7's Avatar
    Jun 2011
    723
    Damn indicator is hit and miss now as well. What wiring should I be checking and whereabouts? Brake, fog and reverse are fine?
    rizzini7's Avatar
    Jun 2011
    723
    Well it looks like the pin has fried off in the connector. Assume you can't just change the connector easily as it looks sealed and wired all the way to the front of the car.
    Have just pushed it very tight onto the pins and seems to be working at the moment. Also can you just buy a new light back plate or does it have to be a whole light unit?
    rizzini7's Avatar
    Jun 2011
    723
    Well appears my fix has now worn off. Is it possible to buy a new bulb holder? Is it hard to change the plug?
    And if I was to buy new led ones which are the best to be looking at?
    Thanks in advance
    Molnboman's Avatar
    Yes Mate, you can buy a new side bulb holder which come wae about 10cm of cable. Shock Horror ...they are about a tenner!...Tr8ups also sells them I believe...but not 100%.
    A
    rizzini7's Avatar
    Jun 2011
    723
    Nice one, will pop into Tps. Didn't fancy a whole new light unit as they seem pricey looking on eBay. I maybe lucky, looks like the bit of pin has come out of the plug so it's just the bulb holder that's faulty now as one of the pins has burnt off.
    Molnboman's Avatar
    Yeagh, good luck.....must say not impressed with the lifespan of those led sidelights. Mine have only lasted a few weeks. May swap back to standard sidelight bulbs if I could just find a brand that weren't yellow coloured. The H7's from Tr8ups seem to be doing well so far though.
    A
  1. Trups Sidelights - Heat issues?
    By ESD1711 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th May 2013, 23:23
  2. Revo comments trial issues
    By Kallel in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th November 2003, 15:01
  3. Newbie: Has S3 performance Issue
    By wizard in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd November 2003, 23:07
  4. Bumper Issue
    By tonyrmay in forum The Welcome Section
    Last Post: 23rd July 2003, 13:32
  5. Sidelights for A3 (97R)
    By [Dave B] in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2003, 16:38
