Volks AutosChris Nott
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Sandra
Thread: Retro fitting cruise control
    Dec 2012
    Birmingham
    214
    Hi, just a quick question.
    Wanting to fit it to my 2007 A4, is it just a case of buying the stalk, plug it in and use vagcom to turn it on?
    thanks.
    Oct 2012
    aberdeen
    111
    you need the switch the column cover & 2 screws total cost from audi when i did it a few months ago was £70 for everything
    one thing you may need is the comms unit for the steering wheel, as you need to have somewhere to plug the switch in
    then its just a case of coding with VCDS
    tbh it took me about 1hr at my mates garage and he coded it in minutes
    Growing old is madetory, Growing up is optional !
    26,720
    Yes but you have to be careful with removing the parts & refitting, as if you damage the slip ring which houses the angle sensor, you have a problem.
    If you need an installer, give me a shout, I can supply/fit it all
    Dec 2012
    Birmingham
    214
    NHN - how much you charge to supply and fit? Thanks!
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,298
    Quote Originally Posted by SinghB7 View Post
    Send NHN a pm and he will give you details.
    NHN likes this.
    Smaller (Local) Events
    Audi-Sport.net online magazine.
    To find Audi-Sport-Net members with VCDS check out the MAP.
    Apr 2013
    140
    Its easy,
    unscrew and remove lower steering shroud
    take airbag off
    unscrew center bolt holding wheel to column
    mark it with permant pen
    slide wheel off
    unplug steering angle sensor
    unscrew a couple screws from indicator stalk
    pry the indicatator stork off (not sure what its call its like a metal plate) slightly
    plug in cruise control stalk
    screw it in
    re connect battery
    check for faults
    code it in
    Puit everyting back
    Thatss a pretty crude guide but its jsut off the top of my head what I did and I havn't done it before and didn't look at any guide apart from coding it in. Its jsut a case of taking stuff apart till you can put it in and the re asseble.
    took me about 1 hour - 90mins tops
    Cheers, James
    26,720
    James with respect, its easy for some people who are geared towards that area of tech as such, when advising others as an installer, its not just to try get the work, before anyone stumps up, but its also to protect someone from causing themselves even larger costs for a job that doesn't warrant it, if you can see they're not very savvy with these things, no offense to others btw, as I don't know others levels of knowledge of these things.
    Most people on the street etc, would never dream of stripping a wheel of, airbag, column etc, so yes they have the diy option, but you have to be honest that the systems they're working on can become damaged if things are not done correctly & they need the correct tools that most don't want/need after doing some mods, so its cheaper to pay someone to do who has the tools etc that are used often, given I've been to some right hash ups in my small time working in this area of technology.
    Overall its not hard to do, but you also cant go into it blind either, as how many times on various forums do you read of people doing things themselves & they say oh dear I broke something because I didnt know etc etc.
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    653
    Sorry to hijack the thread.
    Changing steering module and slip ring in mine with second hand ones. Do I need to code the abs? If so how do I work out the login code? And then is it a case of using the original code I got from scanning the car before install? Im just trying to get all the codes etc.. worked out before starting.
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
  1. retro-fit cruise control
    By IainR in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 15th August 2005, 23:47
  2. Retro Fit Cruise Control on A4 Avant TDI 130
    By kenny_boon in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th April 2005, 17:06
  3. Retro Fit Cruise Control
    By mikeA2B in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th October 2004, 16:49
  4. Retro fitting Cruise control
    By Seizure in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2004, 19:18
  5. Retro fitting cruise control
    By Anito in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd April 2004, 10:35
