Volks AutosMonster Motorsport
Page 1 of 2 12 LastLast
Results 1 to 40 of 61
Like Tree4Likes
Thread: Coming home / leaving home retro fit
    Feb 2013
    38
    Hi,
    ive been searching this for a while now and have found mixed tutorials and methods but am not
    sure which will work for my car.
    I have the a4 b7 2005 s line model with standard headlights no auto lights and no auto dimming mirror.
    this fit is on an a3, will it work on mine? This is exactly what i want.
    cominghomelights - Audi Retrofit
    Ive also found others but im not the best at electronics and not sure about lowline / highline models?
    http://bigskyeuro.com/images/gallery...H_retrofit.pdf
    Any ideas if this would be possible? Or anyone know someone that can do this for me?
    Thanks!!!!!
    RMH1A4cab's Avatar
    I'm in Cruise control
    Jul 2010
    staffordshire
    524
    To check if you have high or lowline take the headlight swith out and unplug it, if your headlights come on its highline and you need a single repair wire and some coding this is what I have, as for lowline that's involves a bit more wiring. I have a thread on here somewhere about it.
    F
    ULL VCDS HEX-USB-CAN Interface available in the staffordshire area pm me.
    Apr 2013
    hoylake
    6
    im also interested in this.... would it make a difference in how you do it if you have auto lights and mirror?
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,487
    Guys we have forum sponsors who do these retrofits all the time. Pm members NHN, N8 and In Car Technologies. x
    NHN likes this.
    Dec 2011
    Glasgow
    195
    Quote Originally Posted by wh1tey View Post
    For the system to work properly it needs the auto lights sensor on the windscreen to be installed and a high line module. If you have auto lights installed then its simply a case of installing a new wire and the switch for the ch/lh lights.
    However if you don't have a auto lights sensor installed you can still have the ch/lh lights working.the only thing with this is that they will work during the day as there is no way for the car to tell if its dark or not.
    I am part way through installing the auto lights install myself and I've wired it all up and I'm just waiting to get the windscreen replaced so that I can then install the sensor. However I already have the ch/lh lights working.
    I also have wired up RHM1a4cab a4 cab so that the ch/lh lights work but without the light sensor
    If you don't have a highline module and only have a lowline module then I believe that there is a relay kit that you can buy but I have never fitted one
    A4 B7 2.0ltr TDI Cabriolet
    Mods
    Puddle lights Illuminated cup holder Cd changer in glove box Interior lighting led upgraded
    Full VCDs
    Feb 2013
    38
    Thanks for all the replies,
    ive been going through all your past discussions...mainly between gaz and RMH1.
    ive done the test and my headlights stay on so mine is a HIGH LINE module.
    so im assuming i just need to buy the switch from audi - part 8E1 919 094 A 5PR
    then (ive taken this from gaz's previous response)
    0.35mm cable is used and
    Pin 7 of the Ch switch goes directly to pin 24 of the grey 32 pin connector (T32b) on the central electric's module
    Pin 4 of the Ch switch does go to pin 20 of the grey 32 pin connector (T32b), but as you can see that this is linked to the main light switch I found that pin 20 of the grey connector was already used so rather than running another cable I soldered the end of pin 4 cable to pin 1 on the main light switch
    is that all in regards to wiring? And exactly what code needs to be put in vagcom? I will be taking this to a local electical specialist who said he'd have a go... im assuming if i show him this he'll understand? lol im useless at fiddly things like this lol
    Is this job done? Or anything further necessary?
    thanks for all the help
    Feb 2013
    38
    Also is this for side lights and fog lights and can they turn on possibly when i take key out of ignition? As for unlock is it possible to have the option for eg them turning of when i open drivers door or is the timeout only way for them to turn of?
    Dec 2011
    Glasgow
    195
    As regards wiring yes that's it it's 2 connections.
    Yes all you need is the switch there are a couple of variants of switch so just make sure you get the right one
    My car just had the headlight height adjuster switch so I brought the variant that has the headlight adjuster and the ch/lh switch.
    As regards coding you just tell the module that there is the light sensor fitted. It will log a fault that the light sensor is faulty but that's just because its not there you just need to ignore the fault code. It doesn't effect the car at all there is also a coding option to change the length of time the lights are on for but I just left this alone at the default setting
    The front fogs and side lights come on on my car. They come on when you pull the key out of the ignition and go off after a set time after the car is locked. Then when you unlock the car the lights come on and either go off when the drivers door is opened or after the allotted time whichever comes first
    Mods
    Full VCDs
    Feb 2013
    38
    Just recieved the part from audi today... Its 8e2 for right hand drive models almost ordered the wrong one...will show the electrician asap n hope he can do it. Thanks
    Feb 2013
    38
    Ne1 kno of someone who can do the install for me? Electrician is on holiday and i pm'd the forum sponsers mentioned above but think hes a bit busy...not got back to me again about it. I live in bedfordshire but am willing to travel to you if need be.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,487
    Quote Originally Posted by Noddy786 View Post
    Did you try the names i posted up? X
    Feb 2013
    38
    Yes i did sandra, thanks for that. I was speaking with nhn about it and said he can do it but i havnt had a reply back since monday and ive messaged a couple of times now so im assuming hes busy or something.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,487
    Maybe he has been busy, drop him another pm x
    27,114
    I did get back to you, stating the lights will cost more than £50 & didn't get an answer.
    Geebo likes this.
    Feb 2013
    38
    Oo i did reply to that...assuming you didnt get it then lol ill send u another pm nw.
    Feb 2013
    38
    Ended up goin to my local electics place as nhn is too busy lol newai hes done all the wiring but is having problems on the vagcom side of things...hes saying it rejects the code...can ne1 tell me exactly what needs to b put in vagcom so i can pass it on? Thanks
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    What code is he trying to input.
    You have to change it so the car thinks it has a light sensor fitted,as gaz says it will throw up a fault in vcds but ignore it.
    I can't remember the exact code and i'm currently miles away from my car.
    F
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    09 central electronics
    • x?xxx: Driving Light Switch
      • 0 = Rain/Light Sensor (G397) not installed (PR-8K0/8K1/9C6/8K4)
      • 1 = Rain/Light Sensor (G397) installed (PR-8K3/8K7/9C7/8K9
    • Change the above to 1
    F
    Feb 2013
    38
    Cheers bud...i thnk thats what hes attempting. He sed evrytime he tried to chnge the light sensor to 1 it boots him out and doesnt accept/save it?
    27,114
    Its not a case of being too busy, its a case of being in the area, the job alone isn't economical to drive to & do for the day I'm afraid, I think that's a fair POV.
    Feb 2013
    38
    fair point mate i totally understand...not a problem...where are you based? if i cant get any joy with the coding would it be possible for me to come down to you? im sure it must be something small he's missing...any suggestions?
    27,114
    You are not allowed to link or post up to counterfeit products, remove it or it will be removed!!
    Feb 2013
    38
    just got back to me and its still not having it...hes saying possibly my main control module isnt compatible? although i did do the check by taking the headlight switch out and my lights did turn on... but my part no is 8E0 907 279 K can you confirm that this is highline?
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    Don't know why your lights came on but that number is for a lowline unit.
    F
    Feb 2013
    38
    Really?!? Tht probably explains it then! Is it much more work?
    Feb 2013
    38
    http://bigskyeuro.com/images/gallery...H_retrofit.pdf will this be the guide i need to follow?
  28. #27
    27,114
    The lights always come on auto when light switch is removed/disconnected, its a safety mechanism they have, so at least if its dark you have a way to see even if switch isn't working etc.
  29. #28
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    Really. It was A8tech who advised me to remove mine to check if I had hight/low line.
    F
  30. #29
    27,114
    Well every car I've ever removed light switch from has turned them on, various chassis, maybe I've avoided specific modules just by pure luck, Jon knows his stuff & I don't like to question him at all tbh as he's usually correct lol, top bloke aswell one I respect highly.
  31. #30
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    He is a top chap, I'll just have to beat him with a stick next time I see him if he is wrong.
    NHN likes this.
    F
  32. #31
    27,114
    May have to use that stick on me instead, although it may bounce of lmao.
  33. #32
    Feb 2013
    38
    Loll electrician is saying it is a highline module aswell?! Confused lol but hes literally taken the whole thing apart nw to try to get to the bottom of it and discovered that pin 24 is actually EMPTY! Thers nothing ther for the wire to be connected to in the first place? So hes suggesting to change the module to 1 tht had light sensors installed?
  34. #33
    Feb 2013
    38
  35. #34
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,346
    Interested in this myself, willing to travel within 150 miles of Birmingham if anyone can offer a decent price, pretty sure mine are high line, will pm around if nobody gets back.
  36. #35
    Dec 2011
    Glasgow
    195
    Sorry I didn't get back to you earlier Noddy789 been a very busy day at work and I've only just stopped
    Yes coding Is just literally just select the light sensor as you have found you have a low line module so the light sensor option is not available
    Swap the module over for high line module which will have a pin 24 and bobs your uncle you will have the feature
    Mods
    Full VCDs
  37. #36
    Feb 2013
    38
    No worries mate n thanks a lot for the help buddy...but wher on earth can i find one? Rang audi just to check n they said £274! And will any highline module work? Is it too difficult to do on a lowline? If so i thnk ill jus take defeat on this one n give up lol cars still at the garage but will need it for thursday so havnt got long.
  38. #37
    Dec 2011
    Glasgow
    195
    There is a relay kit available I think. someone has linked to it on a previous thread this uses the interior light and takes a feed from there to switch a relay this then switches the fog lights on I think .this method is not OEM
    Or replace the module to go the OEM route but as you discovered it can be very expensive
    Keep an eye on eBay they some times pop up
    Mods
    Full VCDs
  39. #38
    Feb 2013
    38
    Guess ill just have to hold tyt for now then lol...wat r the end letters for highline? Isit just f & n
  40. #39
    27,114
    Ping me a PM I can source a highline module & finish the job.
  41. #40
    Feb 2013
    38
    Just did a quik search found quite a few on ebay for reasonable prices :-)
  1. Coming Home & Leaving Home Lights Enabled
    By MarcQuinlivan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2 Days Ago, 13:54
  2. A3 coming Home/leaving Home lights
    By pns2007 in forum VCDS (formerly VAG-COM) forum
    Last Post: 7th January 2013, 21:56
  3. Fitting Coming Home/Leaving Home to a new Black Edition
    By CJ1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th January 2011, 11:53
  4. Vag Com Faults after Coming Home & Leaving Home Lights Enabled .
    By Digzz in forum VCDS (formerly VAG-COM) forum
    Last Post: 3rd February 2010, 14:45
  5. Coming home/leaving home lights
    By S3-Andy in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st January 2010, 13:30
