JMB RetrofitsChris Nott
    May 2004
    21
    2005 v6 2.5 tdi starting probelm
    hi
    for the first time in a while i let my audi hit the reserve light, it wasnt empty, anyway it struggled to start after a while cranking and a big puff of smoke it started then the brake warning lights came on??????? anyway i drove to a station filled it up again struggled to start, i gave it a good run had no problems on the drive was as normal, stopped it gave it 30 secs and again it struggled to start with brake warning light coming on, its been check and showed that there are no fault codes, would this be a leak in a diesel pipe allowing air in ?or something more serious
    thanks for any help
    27,089
    Please do some research before posting, this is just the 1st one I found:
    a4 2.5 tdi red breake warning light flashes on start up!
    May 2004
    21
    there no faults codes surely there would be one if it was ABS controller ? even a intermittent code
    the brake light doesnt always come on when it struggles to start
    27,089
    It was an example to enfuse you to do a search online, there are a number of reasons, you need to research, read & test things like battery, to ascertain where the fault may lay, as we cant diagnose over the internet, we can suggest reasons, but it will need your interaction to get to the bottom of the problem, at least the info provided starts you along the path
    May 2004
    21
    sorry, i have searched online google etc, what is the point of a forum without asking questions and since i cant find the answer i`d thought i`d ask here, maybe someone has had the same problem, i wont know that unless i ask
    i should made myself a little clearer, there is no problem with the battery, it turns over fine, the battery is strong, its like there lack of fuel but when it does starts its fine, drives as normal with no lack of power
    "Live as if you were to die tomorrow, Learn as if you were to live forever" i like to learn off others but if others are not willing to teach thou cannot learn
  1. 2004/2005 A3 2.0 TDi s-line DSG CO2 Emissions?
    By RS84 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th October 2008, 16:27
  2. Tdi Starting problems
    By s1hal in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th May 2008, 20:27
  3. 2.5 TDI Starting Problem
    By PeteS in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 17th July 2007, 11:20
  4. A4 TDI STARTING/MPG/HELP!
    By vw754 in forum Diesel forum
    Last Post: 29th January 2007, 00:40
  5. A3 2.0 TDI Starting problems
    By imported_simey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th February 2005, 20:18
