Badger5Sky Insurance
    dannyboy75's Avatar
    Oct 2011
    Dorset, UK
    91
    Can't delete bluetooth contacts
    Hi all
    Has anyone else had problems trying to delete/edit numbers from the Audi bluetooth phonebook? I can add them just fine, but if I try and amend or delete any, the bluetooth lady proudly says "Function not possible".
    I wondered if there was some sort of PIN code protection on it, but I've gone through all the settings and can't find anything. Google suggests I'm not alone, but I can't find a definitive solution.
    cheers
    Dan
    Audi A4 (B7) 2.0T FSI SE Quattro
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,534
    Which phonebook are you adding them into? Bizarely the BT module has a separate phonebook to the RNS-E, so if you have to delete contacts the same way that you added them.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    27,110
    Yeap +1 if showing as contacts from your cellphone, then delete them via the handset, the directory option I never use tbh, I find it very longwinded & a pita.
    dannyboy75's Avatar
    Oct 2011
    Dorset, UK
    91
    Thanks guys. To clarify, I could never get the phonebook on my iPhone to sync with the in-car thing, so it's not that one. It's just contacts that I've added by voice, using the 'Store name' command.
  1. Mods can you delete my for sale thread.
    By RMH1A4cab in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st March 2011, 14:01
  2. Deleting BlueTooth Phone Book
    By mhill in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th April 2009, 10:56
  3. A3 - Bluetooth Retrofit - Where Can I get this from
    By Marcyboy in forum In-Car Entertainment
    Last Post: 11th December 2007, 09:46
  4. Treo 700wx Contacts Compatibility with Audi A4 Bluetooth
    By mbressman in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd October 2006, 14:43
  5. How can i contact Asn?
    By ianhg in forum Site Support & Announcements
    Last Post: 29th November 2005, 22:01
