EM TuningAH Fabrications
Results 1 to 13 of 13
    KalEl's Avatar
    Mar 2013
    Moray, Scotland
    14
    Help!!! Audi A4 2.0tdi issue
    I have a 2007 Audi A4 Avant 2.0tdi 170, driving hame last night (late) All of sudden glow plugs warning light on dashboard. Car had loss of power had to slow down for roundabout but couldnt pick up any speed so stopped at side of road. Car was still running but no power quickly switched off engine restarted ok but no power. This morning it started as usual but a few seconds in judders & cuts out WTF Any ideas/suggestions? When I was reving it there was smoke coming out the back couldnt see colour due to time. Just had a new DPF filter fitted less than 3 months ago
    Apr 2010
    SWINDON / WILTSHIRE
    72
    Sounds like an injector failure but you'll need a diagnostic scan to be certain.
    KalEl's Avatar
    Mar 2013
    Moray, Scotland
    14
    Injector failure, is it pricey? I have it booked in next Tuesday
    Apr 2010
    SWINDON / WILTSHIRE
    72
    Audi has a recall for 170bhp diesel engine injectors so give a main dealer a call with your cars details.
    Sep 2010
    26
    We had the pre-heaters done on our A3 tdi 140. The engine check light came on then, not the glow plug light. Didn't effect the running of the car though so your's could be injectors. A mate had this prob with a Golf tdi and got some injectors from a breakers yard for next to nothing.
    May 2012
    RETFORD, NOTTS
    1,753
    Considering the level of smoke and lack of power, ive only seen this on cars with faulty airflow meters or boost pipes popped off.
    Where are you based maybe somebody local could check for fault codes with VCDS before sending it into the garage. Have you checked for any abnormalities under the bonnet yet?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    KalEl's Avatar
    Mar 2013
    Moray, Scotland
    14
    Im up the top of Scotland, I foned Audi the previous owner had the injector recall & fixed November 2011 is there any warranty on this part?. I don't know enough about cars 2 look but will get the fault codes & c if a local garage can help. Airflow meters ok is it expensive
    North East
    607
    Quote Originally Posted by KalEl View Post
    I hade a Mass Airflo Meter (MAF) fitted by local indie at my last service for £60. Its literally a 5-10 minute job to fit one .
    KalEl's Avatar
    Mar 2013
    Moray, Scotland
    14
    Well fingers crossed, I can't justify spendin more stupid £s like the dpf. Will update when I find out on Tues.
    Thanks 4 the advise
    KalEl's Avatar
    Mar 2013
    Moray, Scotland
    14
    So it was the EGR valve needing replaced, badly clogged up. Just think its rather fishy how the dpf filter was replaced less than 3 months ago & this wasn't picked up. It must of been clogged up then due 2 the faulty dpf it cud of been cleaned bk then
    Instead that's about £600-700 down the drain, the amount I've spent in the last few months I have put some serious thought getting rid of the Audi
    North East
    607
    A new EGR fitted by an Indy will be around £250, good luck !
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    I'd have tried to clean the EGR myself.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    KalEl's Avatar
    Mar 2013
    Moray, Scotland
    14
    The flap was seazed open wudnt budge, I just hope that's it 4 now. Had enough spent on the Audi this year
  1. Audi A4 2.0TDI 140 Hybrid turbo need help
    By 44nas in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th January 2013, 14:45
  2. 05 Audi a4 2.0tdi s line, hard juddering at high revs. HELP PLEASE
    By vavavag in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 26th September 2012, 13:57
  3. Help- Audi A6 2005, Electronic brake issue
    By mike18uk2001 in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 7th May 2012, 17:43
  4. Audi A3 EGR Valve issue? Help
    By FINEST_A3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th March 2012, 13:26
  5. HELP Audi 80 sport prob
    By lenin in forum General Technical / How To
    Last Post: 21st April 2004, 09:30
