EM TuningVolks Autos
Results 1 to 16 of 16
Like Tree3Likes
  • 2 Post By mm707
  • 1 Post By Darren198712
Thread: Flashing Coil / Glow Plug Light and Limp Mode
    May 2010
    Glasgow
    31
    Hey - I know there's another thread on this somewhere but it's 2 years old now
    So i've got the A4, 57 plate 170bhp version with 83k miles on the clock.
    For the past few months i've noticed that i get a bumpy idle however I've been meaning to clean the EGR valve out to see if this will sort it but not got round to it yet. Well actually I did but I ended up getting down to the last bolt on the EGR and stripping it!!
    Anyway - about a month ago on the motorway I got a flashing light which looks like a coil but apparently is the glow plug light? Also went into limp mode. I had a quick google while I turned my car off and read that it could be related to a wet footwell, esp if it's raining. It was raining so I put it down to that. It hadn't done it again until last week when I've been commuting home from work, 3 nights in a row, on a slight incline on the M74. No rain to blame either!
    I've yet to get this scanned for faults but can anyone from experience tell me what the possible fault could be?
    Also when sitting idle at traffic lights, I can smell a strong fuel smell coming from my car. Excess smoke I think - but i'm not sure if that's related.
    The car has had the injectors replaced under recall too.
    Help :/
    May 2011
    Suffolk
    308
    Hi. Had similar issues with the glow plug light flashing, exhaust immisions light AND dpf light all on at the same time!
    Scanned it (for the life of me i cant remember what it was called) but we replaced a Bosch sensor that is fixed by a single 10mm nut to the bulk head, almost center of windscreen, one electrical plug going to it and two small rubber pipes coming in......
    Replaced it, and so far,,,,,,so good! But get it scanned before replacing random sensors, this paticular one was £40
    Oct 2012
    By your description Was the bosch sensor you replaced the pressure sensor for the dpf?
    A4 Avant B7 1.9TDI Sline
    May 2011
    Suffolk
    308
    Quote Originally Posted by vas67 View Post
    Thats the very one my friend!
    May 2010
    Glasgow
    31
    could it be a badly fitted timing belt? A garage has quoted me 50+VAT just to have a look :/
    May 2011
    Suffolk
    308
    Quote Originally Posted by 5aq1b View Post
    I would be very surprised mate.......Spend the money on a vcds scan...Put a post on here and see if someone locally will scan it for some beer vouchers
    May 2010
    Glasgow
    31
    Quote Originally Posted by tuffy View Post
    not to worry - i've bit the bullet and finally bought a legit cable from NHN :D
    Will post up my log tomorrow!
    May 2010
    Glasgow
    31
    This is the result of my scan:
    1 Fault Found:
    000665 - Boost Pressure Regulation
    P0299 - 006 - Control Range Not Reached - Intermittent
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 20
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 2304 /min
    Torque: 272.0 Nm
    Speed: 125.0 km/h
    71.37 %
    Voltage: 14.24 V
    Pressure: 2492.1 mbar
    Pressure: 1917.0 mbar
    Readiness: N/A
    May 2013
    galway ireland
    hi all new on here,have 07 2.0tdi 170 quattro same issues as you 5aq1b, rough idle,smokey on warm up burning fuel smell,emissions light and glow plug flashing came on few months back,got it scanned cant remember codes,cleared codes but lights came back on again,they come and go,glow plug light seems to flash whenever my girlfriend drives ie slow ha ha,,for some reason my car doesnt go into limp mode.going to bring it into audi next week for free health check(which i got when i registered with audi.ie)to see what they find.
    Mar 2011
    North Wales
    206
    I had that exact same fault, and it was a cheap fix. It's the vacuum actuator on the inlet manifold. Inside there is a diaphram which splits. you have to replace the whole unit. Only about £10 + another £10 for new gasgets. You will also need a couple of cans of choke cleaner to clean the inlet manifold out while it's off. It's quite an easy job. The unit is used to operate the flaps inside the inlet manifold and when split does not function properly.
    Car runs great afterwards
    Here is a pic of the part, it is at the top of the engine near the front. If you want part numbers let me know.
    5aq1b and joeyg79 like this.
    May 2012
    UK
    184
    This happens to me. I replaced mine. TPS will not sell you the vac pump on its own as they will tell you it's part of the manifold. There is a part number on here somewhere which is the same part but its for a passat. I fixed mine last week end.
    Edit
    Part number is S03G129061C
    Tell TPS that part number and they should say its a vac pump
    joeyg79 likes this.
    May 2010
    Glasgow
    31
    I actually think I bought this part as part of my EGR Cleaning project (which I never got round to!)
    Will check the garage shortly.
    Cheers mm707
    Sep 2008
    Nuneaton, Mids
    231
    looking forward to the results of this, my lumpy idle is driving me mad !
    May 2010
    Glasgow
    31
    Quote Originally Posted by unitzero View Post
    you getting a lot of smoke too whilst idle? starts to bloody sting my eyes that's how much I'm getting.
    Sep 2008
    Nuneaton, Mids
    231
    now and then, smoke isnt too noticable but if I leave the car sat on the drive idling whilst messing with my RNS-E the smell starts become very noticeable and I have to turn off the car or just drive off ! stings the throat for sure.
    May 2010
    Glasgow
    31
    now and then, if I leave the car sat on the drive idling whilst messing with my RNS-E the smell starts become very noticeable and I have to turn off the car or just drive off ! stings the throat for sure.
    exact same symptoms here !
  1. Uh..oh... Flashing glow plug light and limp mode :(
    By dubdemand in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1 Day Ago, 17:03
  2. Flashing glow plug light and no accellerator!!
    By blucoop in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th April 2013, 11:51
  3. Latest woe. EPC and ESP lights and limp mode
    By duffy78 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th February 2013, 07:46
  4. Glow plug light and complete power loss
    By norm29 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st February 2011, 12:15
  5. flashing glow plug light and wouldnt run
    By flyingfisherman in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2009, 16:08
