Chris NottSky Insurance
Results 1 to 10 of 10
    May 2011
    Suffolk
    308
    SD card not playing
    Hi all
    ive copied music from my itues library onto a 4g SD card......All playes fine via the SD slot on the laptop, but comes up as unknown files on the rns-e......What have i done wrong????
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,312
    I think RNS-E can only read max 2gb cards.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs.
    Sep 2010
    Telford/Shropshire
    297
    +1 on that.
    make sure its a SD not SDhc card and max 2GB capacity
    2005silver A4 2.0T FSI quattro S-line (saloon)
    18'' alloys,RNS E,Silicone Tip,MTEC brakes,HEL steel braided brake lines,H&R springs (45mm)
    Build thread
    http://www.audi-sport.net/vb/audi-s4-a4-a4-cab-b7-chassis/192911-just-another-build-thread.html
    sammi's Avatar
    verwood, Dorset
    339
    Follow sammi On Twitter
    they are an absolute arse, from memory im sure you can only fit a maximum of 512 songs on and only use up to a 4g sd only card not a sdhc. im sure they can only be read in mp3 format too. i tune my walkman is a good programme for syncing i tunes to the sd card
    26,720
    Are they MP3 for a start.
    Macdoon's Avatar
    Essex
    1,487
    You might have to re-format the card, iirc FAT32
    A4 B8 (09) 2.0 TFSI (211)
    Black Gloss RS4 style mesh grille, Black Gloss fog grilles, Black Gloss splitter trim, Ice White fogs, Tints, Black A8 boot rings, Black Badges, Dynamik boot spoiler.
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    789
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    Not sure on maximum size of card but mine is 2GB and works just fine. I do know the following however:
    1. FAT32 format as mentioned above.
    2. Filenames exceeding 64 characters will not be displayed and therefore cannot be played. I use a program called File Renamer (I think) to address this issue as it allows you to automatically delete characters and shorten filenames to 64 characters on less.
    3. MP3 format files as mentioned above.
    4. Sometimes it will display the file but won't play it (just skips it) as it doesn't like the bitrate. I use another program for this (think it is called Bitrate Changer) and increase the bitrate (I think >256kbps is sufficient).
    HTH, Azeem.
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    May 2011
    Suffolk
    308
    Thanks to everyone that helped..... all sorted, hadn't converted to mp3 before i put it on the card. doh!!!!
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,470
    In all those replies we've had all the usual suggestions - both correct and incorrect. Just to clear up the incorrect ones:
    - the SD card MUST be an SD card and not an SDHC card. This means that the max size is actually 4GB - BUT finding a 4GB SD card now is like looking for rocking horse poo (the vast majority are actually SDHC cards, despite what the adverts say).
    - all fixed bit rates up to 320kbps can be played, plus VBR files
    - the limit isn't simply 512 songs, 512 is the total of songs plus folders (plus playlists if you use them)
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Jan 2007
    Berkshire
    40
    Quote Originally Posted by PetrolDave View Post
    Easiest way to convert from CD to MP3
    1. Open Windows Media Player on your laptop/desktop computer.
    2. Place your CD in your CD/DVD drive. It will auto load and tracks will appear.
    3. Move your mouse and place Pointer (arrow) on your screen over the Top bar of Window Media Player, then Right click. Select TOOLS, then OPTIONS. Click RIP MUSIC. In RIP SETTINGS (FORMAT) select MP3 from drop down menu.
    Also change where you want to save your music. by default it should go into your Music folder.
    Click on APPLY at bottom then OK.
    4. Back in your Windows Media Player playlist of your chosen CD, click RIP MUSIC. It will now rip the music to MP3 format into your music folder.
    5. From your music folder, copy and paste Your new MP3 format music to your SD card.
    6. It should now play in your car.
    Very simple. Once you followed this once it will all make sense.
    Enjoy!
    Audi A6 Avant 1.9Tdi Sport
    Audi A4 convertible 2.0T FSI S-Line
  1. SDHC card not working!??
    By steve1719 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 31st October 2011, 06:58
  2. Symphony will not play CDs!!!!!!!!!!!!!!!!!!!
    By ScottishS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th August 2011, 13:34
  3. Front door not operational after door card swop!??? HELP!
    By sportbackbkd in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th September 2010, 13:16
  4. SD card not working
    By Young un in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th May 2008, 22:48
  5. Replies: 2
    Last Post: 27th March 2005, 02:29
