AH FabricationsVolks Autos
    May 2011
    Suffolk
    308
    Quick bit of Rns-e coding help required
    Hi all
    Now in the process of coding the rns-e......Everything works fine apart from the nav displaying in the dis, we've changed the setting from 62 to 23....code is excepted but nothing appears on the Dis...
    Anyone any ideas????
    Jun 2011
    NW London
    141
    Hi Tiffy,
    I think once you have programmed your destination turn the rnse off and on again and it should appear on dis. I have read somewhere that is is a bug with red dis which is why colour dis comes as standard when rnse is selected from factory.
    cheers
    matt
    Audi A4 2lt 170 TDI Quattro s-line, B7, BRD engine code. Mods so far; cruise control, DPF delete, EGR delete, unicorn remap, B5 perches, RS4 rear arb, RNSE with SDS, 2013 maps with speed cams, aux in, powermax remanufactured balancer, Sachs SRE organic clutch and pressure plate with LUK flywheel. Mods to do; s4 break upgrade, glove box fridge perhaps...
    Jun 2011
    Great Melton Norfolk
    1,340
    All working OK Mark?
    May 2011
    Suffolk
    308
    Spot on thanks Dan. Nice to meet you today.
    May 2011
    Suffolk
    308
    Quote Originally Posted by matthew999 View Post
    Hi Tiffy,
    cheers
    matt
    Thanks Matt
    That's what we needed to do.....Turn off, leave for 20 mins.......Bingo!!!!!!
  1. rns-e code help please
    By gas-man in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd January 2013, 18:30
  2. Fault Codes - Help Required !
    By mikes3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th April 2010, 20:52
  3. rns-e upgrades - help required please
    By monkeyboyuk in forum In-Car Entertainment
    Last Post: 13th August 2008, 11:32
  4. RNS-LOW coding help needed.
    By s8craig in forum VCDS (formerly VAG-COM) forum
    Last Post: 27th April 2007, 16:35
