Results 1 to 21 of 21
    ESD1711's Avatar
    Mar 2013
    Edinburgh
    395
    DIS retrofit - the washer level wire conundrum
    Ok, mucho apologies for ANOTHER dis thread, I know that these are already way too common but after heaps of searching, I'm not able to find what I'm after.
    Basically, got both my DIS and cruise stalk fitted today, no problems there.
    However, when it comes to the running of the wire to trick the washer level circuit, we are a bit perplexed.
    Have read heaps of 'how to' guides which talk about removing a wire from pin 1 in the blue multi plug..... But the plug which we found looked to be a sealed unit which my mate didn't want to go butchering without knowing for sure we were doing the right thing.
    Unfortunately, all the how to guides I look at with pictures, the image links appear to be dead on so I can't see if we are on to the right thing or not.
    So........ Ideally what I'm looking for is pictures of this part of the job, the plug, the wire which is removed and the replacement - the more the better.
    If nobody can help that, some detailed descriptions / instructions on this part of the job would be much appreciated........
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    654
    I've got a link saved on my laptop will try and find it tomorrow if no one else has anything first
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,572
    If you lie in the footwell and look up towards the back of the instrument cluster you'll see a blue plug, secured in place with a swinging lock type plug, shouldn't be too hard to find.
    Audi A3 2.0TFSI S Line SE DSG
    JMB Retrofits - North East Retrofit Company
    ESD1711's Avatar
    Mar 2013
    Edinburgh
    395
    Cheers buddy! I've read about half a dozen how to guides tonight, but the ones with images all seem to be dead and the ones without dont give me the detail I'm after lol, just wanna be certain
    ESD1711's Avatar
    Mar 2013
    Edinburgh
    395
    Quote Originally Posted by jb0o View Post
    yeah I'm pretty sure we had the right plug - just didn't seem like removing wires from it would be particularly easy?!
    May 2012
    RETFORD, NOTTS
    1,716
    Scotch lock a wire onto the correct wire and fix it to earth if your trying to turn the warning off. no need to remove the wire from the plug.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    rizzini7's Avatar
    Jun 2011
    654
    Can you just cut the original wire and earth that?
    Apr 2010
    SWINDON / WILTSHIRE
    72
    Don't remove the wire, just either cut it and earth it or scotch another bit of wire to it and then earth it.
    Jan 2013
    Moray
    228
    Don't scotch lock. I you're going to do it, do it properly and solder it! Scotch locks can cause overheating, shorting and fires. I Passionately hate the things.
    Audi A4 (B7) 2.0TDi S-Line Avant Quattro - Steve Edition in Lava Grey
    BBS Wheels|arm rest|ambipur|345mm S4 brakes|PiperX panel filter|cupra R splitter|Greenstuff Pads|Retrofit Cruise control/DIS|Retrofit Audi Phone|Dension iPod|
    Full VCDS equipped for the Moray area
    May 2012
    RETFORD, NOTTS
    1,716
    Quote Originally Posted by Steve220 View Post
    Given the low load of the wire in question and the OPs difficulty/hesitation to remove the plug/wire, I highly doubt there will be any electrical issues and its a very easy addition to existing wiring with no fuss to complete the job.
    IMO if you are going to go to the trouble of soldering the earth wire, you should consider routing the wire under the bonnet and fitting the level sensor too. Most washer tanks have space to cut and fit such a sensor, but if not replace the washer bottle, as i did with my A3.
    ESD1711's Avatar
    Mar 2013
    Edinburgh
    395
    Cheers for the replies so far folks - appreciated.
    JUst really wanted to make sure i've defo got the right plug / wire really. Fairly confident it is the correct plug but it just didnt look like it would come apart very easily which is what put the doubt in my mind.
    ESD1711's Avatar
    Mar 2013
    Edinburgh
    395
    Had another look at it and having figured out how to remove the blue sleeve (i.e by removing the pink / purple retainer), had it off and the wire out within 15mins.
    Problem solved
    Just need to fit the repair wire and get it all coded up - nowhere near as bad a job as I was expecting to be honest.
    Jul 2013
    13
    HI
    when fitting the earth wire does it need to be done with all the lower steering cowl off or can it be done after you have boxed all the car back up
    regards
    karl
    ESD1711's Avatar
    Mar 2013
    Edinburgh
    395
    You'll be able to do it with the steering cowl in place, but you do need to remove the lower dash panel - comes off pretty easily, 2 minute job
    Newbos's Avatar
    Sep 2012
    115
    It's a blue plug with an orange lock over the top. Just unlock and you will be able to slide block out and then like everyone else has said scotch lock onto pin 1. Make sure you have good contact because you will not want to be upside down in your foot well again unless your a dwarf lol!!!
    Then connect other end to an earth. I connected to a 10mm (I think ) about 2 inches away.
    Hope that helps.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,985
    just take the clocks out and get it that way
    easy to do no need to get in the footwell
    Jul 2013
    13
    Does anyone know where the wire actually goes from pin 1, is there a multi plug at the passenger side somewhere or is that wire direct from the wiper switch.
    bez101's Avatar
    Jul 2008
    7,985
    it heads to the pass footwell behind the kick panel
    where you can connect up for the low fluid sensor
    Jul 2013
    13
    is the multi plug marked or any certain colour wiring or will I have to do a continuity test to determine the correct wire
    Nov 2013
    67
    hi guys, sorry to resurrect an old thread...
    I too am looking for this blue plug. i haven't had a chance to lie down in the foot well and have a look up the back of the dash yet, but is this the plug i'm looking for on the back of the clocks...?
    B6 A4 Avant 1.9TDI Sport 130
    Nov 2013
    67
    never mind... i found it!
  1. Retrofit headlamp washers
    By mjsewell in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd June 2013, 21:43
  2. DIS retrofit - washer bottle sensor
    By Morten88 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th February 2012, 13:37
  3. retrofit headlight washers?
    By skanky in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th September 2006, 06:56
  4. How do you adjust the washer jets?
    By bunny in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th January 2006, 13:19
  5. How high should the coolant level be?
    By ImS3ola in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd November 2004, 17:13
