Chris NottMonster Motorsport
Results 1 to 17 of 17
Like Tree3Likes
  • 1 Post By Molnboman
  • 1 Post By TOM.S
Thread: front S4 Discs and carriers on an A4 Wheel size question
    Molnboman's Avatar
    Right Folks,
    Close to pushing the button on an S4 front Brake upgrade on the Old Bus. Tell me this, If I change up to the S4 disc size ( 345mm? ) what is the smallest wheel I can put on the car. I have RS4 19's with summer tyres which I will know will go on no issues, however, I have 16" Winter wheels and am wondering if these will fit or do I require spacers in order for the wheels to clear the bigger discs and carriers. Lastly, other than the bigger carrier is there any other parts required to finish the upgrade....other than the snazzy S4 brake retaining clips hehehe. Any advice greatly welcomed.
    Happy Sunday,
    A
    May 2012
    596
    I like this upgrade, im also thinking about it. The S4 discs are pretty large I don't reckon 16's would take them. mind you thats a guess on looking at the disc size so may just fit with a few cm spare. someone on here has done it they may be able to say so, cant remember the name tho
    Current - 2006 B7 A4 S Line Saloon 2.0T TFSI Special Edition 220bhp, 18" TTRS Rotors, Ferrari Red front/rear Calipers, 3.5" Powerflow tailpipes, BOSE, Cupra R splitter, Chrome grille slats, S4 Mirror covers, Black/silver leather interior, Debadged, Arm rest delete, LED plate lights, Dectane LED Red/Crystal tail lights. remap/diverter valve soon
    Gone - 2005 B7 A4 SE TDI Avant 2.0 140bhp
    Molnboman's Avatar
    Thanks...the 16's go on just and no more at present without any spacer things, but not sure if they will fit with the bigger discs and they are bigger by 20 odd mil'.
    A
    g00se's Avatar
    Nov 2010
    Reading
    244
    Quote Originally Posted by Molnboman View Post
    A
    Not sure of this helps in the slightest, but the 1 piece vented B7 S4 brakes dims are as follows:-
    Diameter 345
    Thickness 30
    Min Thickness 28
    Height 46
    Bore Diameter 68
    Studs 5
    goose
    Current:
    '06 Phantom Black Pearl Audi B7 S4 - Milltek non res|BMC Panel|034 25mm RARB|SuperPro poly bushes|Apikol poly Snub|H&R Springs|H&R 10mm rear spacers|LCR Splitter|R8 caps|JCap|RS4 Pedals|EBC D/G disks & yellow pads|HEL brake lines|White sides/DRLs|De-tango'd
    '72 Sunburst Yellow VW Karmann Ghia Coupe - 1641cc|Engle 110 Cam|Weber 34 Carb|dropped spindles|Porsche 911 black leather interior
    Molnboman's Avatar
    Quote Originally Posted by g00se View Post
    Diameter 345
    Thickness 30
    Min Thickness 28
    Height 46
    Bore Diameter 68
    Studs 5
    goose
    Goose, that's about as much use as a three legged donkey! hahaha only kidding....Cheers Matey, Aye, am aware of the size of the discs....it'll just be a case of seeing if the calipers will clear the 16's....I don't have to panic till October when I need to change over tae winter tyres by law....so plenty of time to suss things oot!
    A
    g00se likes this.
    Sep 2010
    Telford/Shropshire
    297
    A
    no mate no chance with the 16''.
    You need at least 17'' +
    what i used to do with my previous cars was to keep two sets of 18'' one flashy,blingy and a set for the winter to cope with all the snow,ice,salt & grit..
    and regards that upgrade... one part you might also think of is a set steel braided brake lines and some good brake fluid in order to prevent a sort of spongy feel on the brake pedal once you instaled the S4 set up.
    btw are you doing a complete S4 conversion? i mean front and rear brakes ,or just the front?
    2005silver A4 2.0T FSI quattro S-line (saloon)
    18'' alloys,RNS E,Silicone Tip,MTEC brakes,HEL steel braided brake lines,H&R springs (45mm)
    Build thread
    http://www.audi-sport.net/vb/audi-s4-a4-a4-cab-b7-chassis/192911-just-another-build-thread.html
    Molnboman's Avatar
    Quote Originally Posted by TOM.S View Post
    Thanks for the tips.....I have standard SE 17"s Audi wheels ( which am using right now with Summer tyres ) so it would be case of just finding some winter tyres for them.
    Aye, braided hoses were something I was thinking about. I was only thinking about doing the fronts to be fair. I know the back discs and pads could do with replacing but wasn't going to upgrade them just keep them the same size. Is there some words of wisdom you wanted to share with regards this point. Feel free.....I am not proud, and need as much help as possible with this.
    Allan
    Sep 2010
    Telford/Shropshire
    297
    words of wisdom haha ...
    to be honest with you I'm not an expert either.I have experience with tuning/modding A3's before, being a B7 owner just for a month or so I'm not so sure.
    I've been thinking of upgrading the brakes and since my baby is a quattro I'm a bit confused whether to upgrade the rear end or not.
    the plan for me so far is : front
    source some OEM S4 carriers , combine them with some MTEC drilled/grooved discs 345mm,some good pads of which brand I'm still not sure of (previously used brembo,mintex on A3 as they were spot on),HEL braided hoses,motul fluid.
    as for the rear I would like to know more ,whether its worth upgrading or not.
    if not then I just go for normal size drilled/grooved MTEC discs some proper pads and of course the braided hoses.
    OH and almost forgot the most important part
    paint all the calipers RED
    Build thread
    Molnboman's Avatar
    Hehehehe I can see you have money burning a hole in your pocket!.....like me , if I had the money!
    I reckon the Quattro may be a little more complicated as you wouldn't want to be upsetting anything on those 4WD's purely because it's 4WD.
    There's plenty of options for discs and pads so that should be fun too! I heard of upgraders going for red stuff and green stuff pads.....there' a Swedish company up here doing deals on German Zimmerman discs and red and green stuff pads so may go with them.....no major hurry.
    As for brake caliper.....oh, black will do for me....
    A
    Sep 2010
    Telford/Shropshire
    297
    hey Alan..
    do You know if the calipers (front) on our A4's are the same size as the S4 ones?
    as the staff at audi dealer couldn't confirm that.
    the part number for the A4/S4 are pretty much the same with the only difference being an added letter B for the S4.
    Build thread
    Molnboman's Avatar
    hey Alan..
    I have been doing a wee bit of research on the US and UK Audi owner sites and it would appear that the S4 front calipers are exactly the same as the B7 A4 front calipers....the only difference is the carriers for the discs and the discs themselves which are bigger. not sure about the backing plate if there is one. I have a mucker who works at VAG who will confirm all of this to me this week.
    Here's a link to the ECS disc upgrade which confirms the above ( although they are quoting their own parts for the upgrade on this link. ) ECS b7 S4 rotor conversion
    • What about B6 S4? Same setup as B7 S4 or smaller rotors like B7 A4?
      B6 S4 = B7 S4
      B7 A4 = B6/B7 S4 calipers with smaller rotors/different carriers
    A
    TOM.S likes this.
    Molnboman's Avatar
    Just a wee update...started trying to get codes and parts for the brake upgrade....but nearly crapped mysel when I realised the carriers are 180 quid EACH up here. The pads and discs are not that expensive but carriers are totally ott price wise imho. There are also two different brake caliper types on my age of B7 so I would need to get the style of caliper bang on in order for the carrier to fit correctly. At that price, am thinking it would be more cost effective just to upgrade to the best standard B7 discs I can get and go for VAG pads to match. Unfortunately, EBC don't do Greenstuff pads for my car model....which is a bugger! Not sure if anyone else has recommendations for good quality pads that are not for track days or take too long to warm up.
    Decisions decisions.
    Allan
    Sep 2010
    Telford/Shropshire
    297
    ooh my ****** 180 for a piece metal bracket!!!? You're right might as well be a better option just to get some good aftermarket discs and pads.in this case I can recommend mintex.ferodo,brembo pads. i have experience with all of them and in terms of stopping power/performance i can't complain on any of them.its just a cese of personal taste,budget.
    mintex are cheaper than the other two and perform well,produce more dust thou..
    brembos,ferodos are quite equal if chosen within the same specs.
    regard the discs I'll go for MTEC ones.
    since you have the same engine (BGB) here's a direct link to em
    Brake Discs and Pads for A4 2.0T FSi (200bhp)(BGB Engine)02/05-12/07
    Molnboman likes this.
    Build thread
    Jan 2013
    Moray
    228
    You'll also find the S4 mounting points on the hub are further out which allows for the 345mm disc. This is the position i'm in, geniune S4 345mm discs, carriers and callipers yet when mounted up will only allow the 321mm disc to be fitted. Nice one audi.
    Audi A4 (B7) 2.0TDi S-Line Avant Quattro - Steve Edition in Lava Grey
    BBS Wheels|arm rest|ambipur|345mm S4 brakes|PiperX panel filter|cupra R splitter|Greenstuff Pads|Retrofit Cruise control/DIS|Retrofit Audi Phone|Dension iPod|
    Full VCDS equipped for the Moray area
    Molnboman's Avatar
    Quote Originally Posted by Steve220 View Post
    Steve, so am I reading you right that you have the larger carrier, and they still don't fit? Have you got the right carrier Matey. In theory I understood that they should fit. What's all this then?!!!
    A
    Jan 2013
    Moray
    228
    I've been assured by the seller they were s4 and shown the car they were removed from - reputable seller on eBay too. I need to 100% confirm with audi to make sure they are the right carriers, but they are pretty big and I don't think I'd want to go bigger due to material stresses.
    Molnboman's Avatar
    Steve, Is there a code on the carriers? I might be able to verify what chassis they are for, for you over the next couple of days.
    A
  1. Hot wheel(s) - New brake discs and pads...smoke from one wheel!
    By murkins in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th August 2012, 17:31
  2. Audi a3 1.8t front brake discs and pads help
    By L3WJX in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th September 2010, 19:32
  3. front / back discs and brake pads
    By khalil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th May 2008, 12:08
  4. 170 TDI front discs and pad upgrade?
    By richjohnhughes in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th December 2007, 23:32
  5. Recommendations for front discs and pads
    By andyhud in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th August 2006, 16:34
