Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By jdp1962
Thread: Scuttle / Plenum drainage issues
    ESD1711's Avatar
    Mar 2013
    Edinburgh
    498
    Follow ESD1711 On Twitter Visit ESD1711's Instagram Channel
    Ok, so whilst fitting the scuttle covered in this thread:
    Battery/scuttle cover.... wheres the best place to get them
    I've come across a potentially serious issue with the A4. It's been covered before, but its not one I'd have known a thing about without looking for - I'd urge you all to go check this on your own car.
    Basically, the drainage plugs in the scuttle get blocked up and rather than pour back out through the bottom, any rain water or whatever else that runs down your window gathers in your scuttle, effectively turning it in to a bath.
    This can lead to serious issues with leaking interiors and, worse still, faults with your CCM.
    Thankfully I've had no issues and it doesn't appear like I've any leaks anywhere, but when checking, mine was holding a LOT of water.
    The fix I was told when visiting audi is just to remove the rubber grommet from under your battery, which I've now done.
    However - I'm not convinced the grommet I've removed is the correct one, as I did so just with everything in place and reaching under the battery. Are there any other grommets around there which should stay in place?! The one I've removed is pretty large and doesn't have any holes in it?!
    Its probably better to remove your battery and get a better look, but its chucking it down here just now so I just did this quickly with everything in place.
    I'd recommend you all go look in your scuttle though to make sure.
    Aug 2011
    south aberdeenshire
    26
    Mine was full of water and I did the exact same as you removing the grommet under the battery and the water drained away. I think there is another one on the opposite side under the break servo..
    ESD1711's Avatar
    Mar 2013
    Edinburgh
    498
    Yeah, I'm 99% sure I removed the wrong one. But I'm gonna whap the battery out and get a better look today.
    This is the one I removed.... It did the job or draining the scuttle, but defo not the 'correct' one
    Aug 2011
    south aberdeenshire
    26
    I think that is the same one as I removed, looking at it seems the right dimensions, but tbh i didn't even see it as I pushed it inwards and left it there.. I guess if the water drains then that is problem solved..... What is that dot in the middle.?
    Aug 2011
    south aberdeenshire
    26
    Good luck with removing the battery by the way.... I tried but gave up as it didn't seem to want to move....
    ESD1711's Avatar
    Mar 2013
    Edinburgh
    498
    As suspected, the one I removed above was the wrong one..... Although I'd imagine it would do the job anyway!
    Got the battery out and got rid of the two proper drainage plugs today. The one under the servo wasn't too bad, but the one under the battery was properly clogged up.
    Problem solved now though
    Aug 2011
    south aberdeenshire
    26
    Good stuff, glad you got it solved... I basically was feeling around under the battery and popped a grommet which let the water drain so never saw the layout but was well glad to get rid of the water.
    ESD1711's Avatar
    Mar 2013
    Edinburgh
    498
    Yeah thats basically what i'd done originally and removed the grommet pictured. In fairness, it does the job.
    The actual drainage ones are a bit deeper in though - think it'd be hard to reach that far back from just feeling about. It becomes a lot more apparent when the battery comes out.
    Just really surprised that there's not more said about this - i've been floating about the forum for a few months and hadnt seen it mentioned before...... massive design flaw that effects a whole host of different models.
    wangdoodle's Avatar
    Apr 2013
    34
    I had this when I went to view my A4 & bought it to the attention of the dealer,so think I'll re visit it!
    One of mechanics came out with a piece of wire & prodded about until it drained.
    I couldn't believe how much was in there,about a quarter of the way up the battery....could have put gold fish in there!!!
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    821
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    I've never bothered removing the grommet before but don't really seem to have this issue (unless someone has already removed the grommet from before). Is this an issue affected across all A4's?
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    Chris-Vspec's Avatar
    Mar 2013
    Verwood, Dorset
    248
    I know it affects the B6 and 7 not sure about the 5 and 8
    ESD1711's Avatar
    Mar 2013
    Edinburgh
    498
    Couldnt tell you a comprehensive list, but I know its across a LOT of different models, Not just A4's and also in to things like Passats and such like too.
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,244
    So why are the grommets there in the first place?
    07 2.0T SLine SE V2 Quattro, Full Milltek with hi-flow sports cat, APR Stage 2+ 280BHP/325lb/ft, APR HPFP, K&N panel, S4 alloys, Spacers, Black Optics, Eibachs, RS4 grill and fogs, Fog tints, RS4 ARB, RS4 Gearstick, LCR splitter, Black Calipers, Drilled discs, Debadged, Colour DIS, Bose, Adaptive Xenons/DRL, Black/Silver Audi Exclusive leather, Audi Carbon inlays, carbon difuser/B pillars, RNS-E+/Bluetooth, Cruise, Int/ext light packs, Rain/light sensors, mudflaps, LED plate/side/boot/interior
    ESD1711's Avatar
    Mar 2013
    Edinburgh
    498
    The grommets DO drain water away to begin with, but over time the become clogged up and stop functioning.
    I believe they are there to stop road spray / dirt etc coming up the way but given your inner wheel wells and under tray and such like, I'd imagine the risk that poses to be significantly lesser than that of them becoming clogged and flooding your scuttle.
    The only thing I can liken them to would be a cone. Probably about the width of a two pound coin at the top and probably about the width of a straw at the bottom..... So it doesn't take much to block them, and when they block..... They just fill up and become useless.
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Last time I tried to shift the battery I nearly put my back out, it ain't easy.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Quote Originally Posted by Wrath View Post
    Plus One!
    Wrath likes this.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Tiffy's Avatar
    Mar 2013
    Warwick
    354
    how did you guys remove the battery in the end???....i want to cxheck mine
    2007 Audi A4 B7 S-Line Avant 170 TDi Special "Black" Edition
    Genuine 19" x 9 Bentley GTC 5 Spokes
    Full Interior LED Light upgrade
    Ambiant "Submarine" Interior lighting
    Seat Leon Cupra R Splitter
    LED rear NumberPlate Upgrade
    Headlight, Fog Light and Side Light White Light Upgrades
    Eibach SportLine Springs 50/40
    Privacy Glass
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Quote Originally Posted by Tiffy View Post
    You have to undo a securing bolt that is positioned on the "floor" of the plenum chamber, front centre, between the battery and the forward bulkhead. It's practically invisible, so you have to remove every cover and all the little ancillary bits and pieces around the battery, then stick your head right up to it and peer down. Then you'll see where it is.
    I forget what torx size it is, but use a long bar to get to it, then break your back lifting the battery out.
    I checked my plenum chamber yesterday (with the battery in place, that is). No sign of any water at all.
    ESD1711's Avatar
    Mar 2013
    Edinburgh
    498
    Yeah the sheer weight of the battery and its location makes it a bit awkward to heave out.
    As said though, you shouldn't need to go as far as that to check it. If the plugs are blocked, you'll know just by checking with the battery in place as there will be a build up of water.
    If you can't see any water in the bottom of the chamber, you're ok..... For now. Check it regularly though would be my advice
    Apr 2011
    Somerset
    72
    Just a note for everyone, I ordered the trims for the plenum chamber from audi and went to pick them up today. At the time I asked about codes for removing the battery for radio etc as obviously needed to disconnect the battery to remove these drain plugs and to my surprise they said they would whip them out there and then for me. They had it about 5 mins in the workshop and was back in the courtyard minus one bung, no need to remove battery! The bung under the main servo was still there but at least the other had been removed, all he seemed to do was jack the car under the engine to gain better access, not sure how but saved me the job! Just got to fit the trims now!
  1. Just had 1.8T Sport chipped... few issues?
    By brixo in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th February 2004, 10:42
  2. Revo comments trial issues
    By Kallel in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th November 2003, 15:01
  3. New A3 DIS tiny issue
    By luisdinis in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th November 2003, 08:23
  4. Newbie: Has S3 performance Issue
    By wizard in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd November 2003, 23:07
  5. Bumper Issue
    By tonyrmay in forum The Welcome Section
    Last Post: 23rd July 2003, 13:32
