Badger5JMB Retrofits
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By A4_MaJiK
Thread: Honda to Audi.....!! Sporty choice to Sensible choice....
    Here is my old car, i traded it in for
    This......
    I'm well pleased with the B7 S-line SE with all add the options makes it a pleasure.
    Had the car for 5 weeks now and only a few issue with the B7.
    The dealership (honda) changed the oil coolant unit (not sure on the correct term) and flushed out the system 3 times before picking the car up after that and i'm still getting surplus oil in my coolant header tank took it back and flushed out the system and now still have the surplus oil in my coolant header tank.
    Yesterday driving to work the Min. oil light flashed up....! but after checking on the oil level this morning the level is at Max..!
    I'm a little confused could this be linked with the first issue or something much bigger???
    I never had a oil problem with my Type R and thats a high reving engine! Any idea or guidance would be welcomed.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,447
    Hi, welcome to audi-sport.net. Someone will be along to advise you shortly. Enjoy the forum. x
    Craig Cull's Avatar
    Oct 2011
    Leeds uk
    1,135
    Visit Craig Cull's Youtube Channel
    Is the oil light amber or red mate?
    Craig Cull's Avatar
    Oct 2011
    Leeds uk
    1,135
    Sounds like loss of oil pressure, head gasket?? What engine is it? 2.0t fsi?
    It was amber mate. Like i said before don't know if the two issues are linked, but the oil levels are at Max...
    No 2.0 TDI 170
    Craig Cull's Avatar
    Oct 2011
    Leeds uk
    1,135
    Maybe just a faulty oil level sensor, amber is just oil level as far as I'm aware. The red one is a case of stop no matter what. That's the case on the 2.0t fsi anyway. Maybe someone with more knowledge on the diesel can help. Hope you sort it mate
    Cheers thanks for that. I might get it in at a VAG specialist for a look over.
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    821
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    Welcome to the forum mate. Looks like you've turned to the dark side of diesels as I did last year too haha. As mentioned above, yellow oil light is for oil level. I'd get diagnostic codes scanned to see if anything pops up, might be a faulty oil level sensor. Not difficult to replace but just means you have to replace your oil so I'd personally wait till the next oil service to get it done (if it is that which is the problem).
    Azeem
    Hulmie likes this.
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    Cheers A4_MaJiK much appreciated.
    B7_FUR's Avatar
    Avantee
    Jan 2013
    Worcestershire
    346
    Nice looking car mate, welcome to the forum
    A4 Avant B7
    LED Rear Lights - Mesh Grill - SLC Splittler - Ice White Fogs - Tints - Devil Eyes - Ambient lighting - LED interior
    ESD1711's Avatar
    Mar 2013
    Edinburgh
    498
    Follow ESD1711 On Twitter Visit ESD1711's Instagram Channel
    Haha pretty much the exact same move I made.... 55 plate premier edition CTR to a B7 diesel avant
    ben.w93's Avatar
    Sep 2010
    Devon/Cardiff
    213
    Congratulations on your swap, that 170 engine is notorious for injector problems. We had a similar problem with oil in the header tank of our 170 Touran, went into VW and they did the infectors as a recal, ended up having a new engine and turbo with VW fitting the bill. Lost faith in the car and went into an A4. I hope I haven't scared you, but after our experience with that engine, I would stay clear of the 170.
    2008 A5 3.0TDI
    Sep 2010
    Telford/Shropshire
    365
    as said above it can be the oil level sensor,clogged oil pick up pipe-resulting in loss of oil pressure,or oil pump issues.get it checked scan for fault codes asap. if u leave it like that sooner or later u might get a serious issue, spending lots of cash on fixing/new engine in worst case.
    Proud owner of a:
    2.0T FSI quattro A4 S-line (saloon)
    Build thread
    http://www.audi-sport.net/vb/audi-s4-a4-a4-cab-b7-chassis/192911-just-another-build-thread.html
  1. Help please on choice of audis.
    By rmstu in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd August 2012, 00:20
  2. Audi A3 wheel choice
    By stevegti2 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th March 2012, 22:27
  3. Moving from Honda to Audi
    By frosty1302 in forum The Welcome Section
    Last Post: 14th July 2011, 10:30
  4. Tyre choice for an S3
    By Nogaro in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th September 2003, 11:25
