AH FabricationsBadger5
Page 1 of 2 12 LastLast
Results 1 to 40 of 56
Like Tree2Likes
Thread: A4 avant 3.0 sline tdi faults
    Apr 2011
    Somerset
    71
    Hi all,
    So it's come to getting a bigger car and I've been looking at a 2007 3.0tdi sline avant about 86k, it's in mint condition with a few nice extras but just to keep my mind at rest are there any faults I should look out for. It has been remapped with a mil tech exhaust so is the extra power an issue for any components?
    Searching the forum I've come across the swirl vanes which might be a problem but I can't seem to find anything major.
    Anything would be great as cant decide if its a deal breaker or sealer!,
    thanks
    Mr-C's Avatar
    Feb 2013
    Chorley
    178
    I have the same car same year, TBH they are a pretty solid lump. On another note they go like stink and return amazing MPG
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,657
    Yup, I second what Mr-C says. I have an 07 3.0TDi Quattro. It's an SE Automatic, and is a supremely smooth and swift mover. Yes there are problems with inlet manifold swirl flaps, but there are now lots of ways of fixing this that don't involve Audi's recommended solution of replacing the entire assembly at £700 a go.
    The extra power shouldn't be an issue. All I would say is that you might want to upgrade the brakes.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Apr 2011
    Somerset
    71
    Thanks both, I think I've pretty much decided on it just didn't want to hear about any nasty surprises after. I did think about the brakes need to run it for a while then decide. The swirl vanes, is there a thread on here how to replace them?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,657
    Quote Originally Posted by ollie86rn View Post
    Let me have a dig about, and I'll find what you need to know.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,657
    There are quite a lot of threads on this (I've even contributed a couple myself) which a search should throw up for you. Essentially; the inlet manifolds on 3.0TDi models have swirl flaps inside, mounted on spindles which are attached by little drop links to electric motors mounted on the outside of the manifold. The mechanism wears out prematurely so the linkages become loose and sloppy (sometimes the drop links become detached at one end - usually the spindle end). The looseness causes the engine management system to detect an error in the amount of movement in the flaps, and the engine warning light comes on. This causes a slight drop off in performance but not by very much. However, the car will fail an MOT.
    Audi's official solution is to replace the entire manifold, flap and motor assembly, at a cost of around £700 per bank. A less drastic solution is to have the mechanism repaired and modified (I had that done on mine by Fontain, the indie Audi specialist from whom I bought the car) at a cost of £225 per bank. If you are mechanically gifted yourself, here's a link to a repair guide. It's taken from an A6 forum, but it's the same engine so everything still applies.
    The least costly option is to leave the faulty linkage as it is, and have the fault code mapped out to that the engine management system just ignores it. Here's a link to a firm that offers this service - FR&R Tuning. They are based in Lancashire but have franchised agents all round the country. Just scroll down and you'll find the relevant section covering 2.7 and 3.0 litre engines.
    I fixed mine using a combination of the Fontain modification and an FR&R remap.
    Hope this helps.
    scotty76's Avatar
    Nov 2011
    Berkshire
    1,062
    Quote Originally Posted by jdp1962 View Post
    I seem to recall you had the fault mapped out later? Do you think you would have done the Fontain modification if the remap had been available earlier? Not having a dig, just curious.
    As an aside I always read the 3.0TDi threads with sadness/jealousy. I looked at both the 3.0TDi and 2.0T FSI and eventually bought the 2.0T. With hindsight I wish I'd bought the 3.0TDi with an auto box. Silky, smooth power. Ho hum.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,657
    Quote Originally Posted by scotty76 View Post
    You're right, I did do the mod first and the map later. I think I would still have done it that way, because in my case, the drop link had detached itself completely from the spindle, so the flap was completely inoperative. Having it modified first ensured the flap became operative again, albeit still with sufficient wear in the mechanism to generate a fault. The map then eradicated the fault code so that the ECU ignored it.
    scotty76 likes this.
    Apr 2011
    Somerset
    71
    Thanks for the information think ill email the seller and see if he has had them done, do you know what the approx mileage is for them failing?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,657
    Well mine first started showing a warning light at about 73,000, but I imagine it varies from car to car.
    Mr-C's Avatar
    Feb 2013
    Chorley
    178
    Brucey bonus for me is mine is a manual so RFL is £260
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,657
    Quote Originally Posted by Mr-C View Post
    Mine too even though it's an automatic.
    Apr 2011
    Somerset
    71
    So emailed the seller and he hasn't had them done however hasn't had any lights on the dash either! Spoke to an independent audi service garage too and he says he usually has them come in for repair between 80k-90k, the one I'm looking at is on 86k!! I know it all depends on how you drive it and luck but i don't fancy buying a new car to then spend £1500 on it! May offer a dropped down price and see what he says as other than that i really cannot find anything else wrong with it.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,657
    Ah but that's the point; you don't need to spend £1,500. Use the issue as a tool to bargain him down a few hundred pounds, then if you go get a problem later, go for a low cost solution like the FR&R map, and you're quids in.
    Apr 2011
    Somerset
    71
    Yeah thats true, think I'm looking too much into it tbh. Just to confirm if the fault does raise its head, there is no risk to destroying the engine like a mates BMW did as it sucked the vane through the manifold!!
    Mr-C's Avatar
    Feb 2013
    Chorley
    178
    I think auto Avant's are the big £450 job
    Mr-C's Avatar
    Feb 2013
    Chorley
    178
    You can actually buy the component parts and fix yourself for not a lot or if you look on ebay £345 gets you 2 COMPLETE INLET MANIFOLDS KIT 2.7 3.0 TDI AUDI VW A4 A5 A6 A7 A8 Q5 Q7 TOUAREG | eBay Or pay £1500 at Audi. Buy the car enjoy the car and if they go then its hardly the end of the world
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,657
    No that doesn't happen; it's very much a BMW party-piece.
    Apr 2011
    Somerset
    71
    Ha thought as much, cheers all will let you know how it goes
    Apr 2011
    Somerset
    71
    Out of interest from current owners how much do you reckon it's worth from the specs below, I have my thoughts just interested what others think
    2007 b7 a4 3.0tdi quattro sline avant manual
    sprint blue paint
    86k
    bose sound system
    privacy glass
    storage pack
    refrigerated glove box
    Miltek stainless exhaust
    remaped
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,657
    sprint blue paint
    86k
    bose sound system
    privacy glass
    storage pack
    remaped
    sorry mate, I bought mine three years ago and am very out of touch on current prices.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,657
    That makes sense. I seem to recall my CO2 emission rating is only about 1 or 2 under the threshold, so the extra weight and drag of the Avant might be enough to tip it over into the next category.
    Mr-C's Avatar
    Feb 2013
    Chorley
    178
    sprint blue paint
    86k
    bose sound system
    privacy glass
    storage pack
    remaped
    Just tell us what he's asking for it and I'm sure we can pass judgement easier
    Apr 2011
    Somerset
    71
    Asking £9700
    Mr-C's Avatar
    Feb 2013
    Chorley
    178
    Sounds fair to me
    May 2013
    41
    this is helpful for me looking out for one over next month, do these suffer from injector problems like the a6 ?
  28. #27
    Apr 2011
    Somerset
    71
    Quote Originally Posted by moggytom View Post
    From what I've researched i haven't come across it yet, that's not to say they don't though. The inlet vanes seems to be more comman
  29. #28
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,657
    I'm not aware of injector problems with the 3.0TDi; I thought it was more an issue for the 2.0TDi.
  30. #29
    May 2013
    41
    I'd you look on the a6 c6 section on here there horror stories of them costing a small fortune to replace :/
  31. #30
    Apr 2011
    Somerset
    71
    So i see, seems like luck of the draw again to them failing. Does anyone know where the engine code is on the B7 A4?
  32. #31
    May 2013
    41
    that's what put me off and a6... plus there the size of a large barge haha,
  33. #32
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    272
    Reference docs: TPI 2014211/7 Vehicle pinks or judders in warm-up phase- A8 3.0, 4.2, A4, A6, Q7 2.7, 3.0 TDI
    Customer statement / workshop findings
    A8 3.0 TDI, 4.2 TDI; A4, A6, Q7 2.7TDI, 3.0 TDI - vehicle pinks or judders in warm-up phase.
    As a result, the adjustment of the injection is incorrect and combustion noises can be heard, sometimes in connection with juddering or misfiring.
    Technical background
    Complaint in the injector production.
    Production change
    Modified injector production from Chassis No:
    A4: with 3.0l TDI from: ........
    A6: with 3.0l TDI from: ........
    Cabriolet: with 3.0l TDI from: ........
    A8: with 3.0l, 4.2l TDI from: ........
    Q7: with 3.0l TDI from: ........
  34. #33
    May 2012
    UK
    184
    I can't see how it can fail? You can advise that the engine management light was on. But if it passes a smoke test then it's passed?
  35. #34
    gupsterg's Avatar
    Jun 2012
    272
    Early V6 TDi has some production issues ...
    Chain rattle being the biggest costing but by 2007 the chain tensioner production issue was solved ...
    Early injectors on the V6 TDi were poorer but by 2007 this was also improved ...
    The early MY2004/2005 Tiptronic had older TCM software & oil but by MY2006 this was also improved ...
    My own opinion is the 2007 production year V6 TDi is more sound than a MY2004/2005/2006 ...
  36. #35
    May 2013
    41
    Il be looking at a 2006 one auto. Would I be best trying to get an 07 one ?,
  37. #36
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,657
    Have you driven an A6? I have, and it's a lot more agile than a A4.
  38. #37
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,657
    Quote Originally Posted by Darren198712 View Post
    That was my understanding, that a lit earning light would result in a fail, but I have been known to be wrong before.
  39. #38
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,231
    The new rules state an engine light on is a failure, even a bulb warning light can be a fail I believe i.e. you have LEDs that aren't canbus friendly.
    07 2.0T SLine SE V2 Quattro, Full Milltek with hi-flow sports cat, APR Stage 2+ 280BHP/325lb/ft, APR HPFP, K&N panel, S4 alloys, Spacers, Black Optics, Eibachs, RS4 grill and fogs, Fog tints, RS4 ARB, RS4 Gearstick, LCR splitter, Black Calipers, Drilled discs, Debadged, Colour DIS, Bose, Adaptive Xenons/DRL, Black/Silver Audi Exclusive leather, Audi Carbon inlays, carbon difuser/B pillars, RNS-E+/Bluetooth, Cruise, Int/ext light packs, Rain/light sensors, mudflaps, LED plate/side/boot/interior
  40. #39
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    816
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    sprint blue paint
    86k
    bose sound system
    privacy glass
    storage pack
    remaped
    Another diesel Sprint Blue!? You're kidding me. First time I've come across another Sprint Blue B7 diesel.
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
  41. #40
    gupsterg's Avatar
    Jun 2012
    272
    If I was buying again I'd go for something which had a minimum of production date of 2007 , so first registration year 07/57 ...
    I bought a 2005 A6 3.0 TDi ... chain rattle fix is engine & gearbox out job@indi = £2K ...
    Mine had 70K on clock@purchase, @80K 3x injectors out of spec, DIY@home install of 6x injectors £1280 ...
  1. New brake pads for A6 Avant 2.5 V6 TDI Sport
    By fjtwelve in forum Handling
    Last Post: 13th April 2010, 15:46
  2. 2006 Avant 1.8t sline
    By larry1 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 27th January 2007, 21:29
  3. Buying a A3 Sline TDI soon. Few questions...
    By Mikey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th November 2006, 20:36
  4. Audi A6 Avant 3.0 V6 TDI by Nothelle
    By TDI-line in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 24th September 2005, 00:01
  5. A6 Avant 2001 1.9 TDI - Styling options
    By imported_oxford in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 16th August 2004, 11:10
