Badger5EM Tuning
    Jun 2009
    North Cornwall
    171
    Blown pipe off EGR Valve? PICS
    Hey guys, I was driving earlier and experienced a loud pop, like a pipe coming off. Followed by a serious lack of power and a noise I can only describe as loud, exhaust, sounded a bit like a V8 Cobra lol.
    Anyway, when I lifted the bonnet I noticed a metallic pipe had popped out of what I think is the EGR Valve?
    Pics below.
    Is this pipe meant to be securely attached or is it just a push in? It took a bit of effort to get it back into position but I'm not convinced it won't come out again!
    I've attached 3 pics. It's the copper looking pipework on the bottom left of the engine as you look at it.
    Any help appreciated.
    Jun 2009
    North Cornwall
    171
    Anyone?
    marky67's Avatar
    Feb 2011
    Solihull
    56
    Not an expert.... but pretty certain that pipe should be attached to the flange... ie welded.
    Hopefully that can be done, otherwise it looks like a replacement
    A4 2.0 TDi 170 Quattro S Line
    Phantom Black
    Mr-C's Avatar
    Feb 2013
    Chorley
    180
    Happend to me a few years ago, it was taken off an welded for about £80 if I recall and lasted years after that.
    May 2012
    UK
    184
    This happened to mine whey I first brought it, the pipe cracked from the Manifold to the EGR cooler where the Zig Zag is. The pipe was part of the EGR cooler and was expensive so I ended up getting a EGR delete remap from Unicorn Dev. great service!
    after that I had to blank of a few pipes and do a bit of plumbing. I had to blank off the manifold pipe and blank out the EGR valve. I also removed the EGR cooler as once the egr has been removed the cooler does nothing.
  1. Another 2.0TDI EGR Valve Cleaning Thread - with before and after pics.
    By Richardesty in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1 Week Ago, 16:16
  2. Metal clip holding boost pipe to EGR valve
    By N11KDJ in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th March 2013, 22:16
  3. Blanking the egr valve off?????
    By stuart.garlinge in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th October 2011, 13:11
  4. Replies: 2
    Last Post: 9th March 2008, 16:47
  5. EGR Valve vaccum pipe? And random squeek between 1800 and 2100 rpm?
    By Bigman in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th January 2008, 11:15
