Results 1 to 24 of 24
Like Tree1Likes
  • 1 Post By ajax1976
Thread: Essential upgrades for B7 A4 ?
    Apr 2013
    Greenwich, London
    27
    Hi all,
    I have recently bought a 2006 A4 2.0T FSI S-Line Cabriolet, and am keen to understand what I should do first regarding upgrades, after selling my previous car I've got about a £1k to spend now, and was wondering what to do, what makes the most difference? What's important to me is handling and comfort (I tend to do mostly Motorway driving) I'm quite happy at present with 200 brake but would like to possibly chip the car at some point. Aesthetically I'm happy with my wheels and I actually quite like the grill, anyway would be keen to understand what you experts would recommend.
    Thanks very much
    Mark
    Chris-Vspec's Avatar
    Mar 2013
    Verwood, Dorset
    248
    Eibachs definitely, cupra splitter makes a huge difference to the front end. I would also opt for a forge diverter, makes the car feel more alive and a must if you are thinking about a remap. All can be done well within your budget.
    Apr 2013
    Greenwich, London
    27
    Thanks Chris,
    Forgive my lack of knowledge but what is a forge diverter?
    Mar 2013
    Verwood, Dorset
    248
    I'm probably not the best to explain it but I will have a go, the diverter valve sits below the turbo and basically allows the turbo to build pressure providing the car with power. The standard audi valves are prone to failing as they use a plastic diaphragm that is prone to splitting, if this happens then all the boost that the turbo is making is being lost kinda like a boost leak. The forge unit is piston based and therefore more reliable and the piston control is spring based, the more boost you produce the stronger the spring you require which is why I said if you we're thinking about a remap then the forge is a good bet as the spring rating supplied is suited to a mapped car meaning you get the most out of the power hike.
    In the last week I replaced my standard audi diverter for a forge one as I am having my car mapped next week, my original diverter that came off the car looked in good condition there were no visible tears in the plastic diaphragm, but once the forge was on I noticed an immediate improvement in throttle response, turbo seems to spool sooner and the lag between gear changes has gone, before the car felt a little sluggish between changes. I am really pleased with the results and definitely a modification I would recommend especially if you want a bit more power
    Apr 2013
    Greenwich, London
    27
    Hi Chris,
    Thanks so much for your detailed response, any chance of pasting a link as to where I can get hold of one of these beautys!
    Mar 2013
    Verwood, Dorset
    248
    Here you go I bought mine directly from forge Motorsport
    Forge Motorsport | Alloy Fabrication
    Apr 2013
    Greenwich, London
    27
    Brilliant stuff thank you, a good first investment!
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    479
    RS4 rear ARB is a must, sharpens handling with no loss of comfort, cheap suspension mod too
    Apr 2013
    Greenwich, London
    27
    Thanks Ajax, I have to say the handling is definitely not as tight as my old Alfa, an anti roll bar is also added to the list!
    Sep 2010
    Telford/Shropshire
    365
    I'll jump in the conversation if you don't mind. where can I get a RS4 arb,how much were talking about?
    as you said its a cheap mod.
    Proud owner of a:
    2.0T FSI quattro A4 S-line (saloon)
    Build thread
    http://www.audi-sport.net/vb/audi-s4-a4-a4-cab-b7-chassis/192911-just-another-build-thread.html
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    479
    Think the ARB is around £70 from dealer, I got a brand new one for £30 on a forum, pop up on Ebay from time to time. You'll need new bushes to suit the wider diameter bar that are around £6 each and brackets for the bushes are also around £6. There's no need to replace your drop links and fitting bolts unless they're goosed.
    TOM.S likes this.
    Apr 2013
    Greenwich, London
    27
    Lovely thank you, any other recommendations?
    Apr 2013
    Greenwich, London
    27
    Apr 2013
    Greenwich, London
    27
    I think I've got my 'wish' list...(priced to include fitting)
    Eibach springs £350
    RS4 ABD - £120
    Re-map - £280
    Air filter - £50
    Forge Diverter - £300
    I've guessed the fitting price, and all in I'm about £100 over my budget - now to get it priced up properly!
    Thanks for all your help
    Mark
    Olly P's Avatar
    My other cars a mk2 Golf GTi
    Dec 2008
    Oxford
    686
    Remap would be top of my list. I've got a revo remap on mine and it made a noticeable increase in performance!
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    479
    One thing to bear in mind is that as you have an S line it is already lower than stock A4 so these Eibachs will only drop your car 10-15mm. Eibach also do a 50/40mm kit that might be more suitable, I've forgotten the name of it. H&R also do great springs, 35mm that drop a shade more than the 35mm, I have them and they suit me perfect, lower but still 100% useable. If you do a search there's loads of threads on lowering springs.
    Mar 2013
    Verwood, Dorset
    248
    Quote Originally Posted by Cravatekid View Post
    Eibach springs £350
    RS4 ABD - £120
    Re-map - £280
    Air filter - £50
    Mark
    dpm performance do the 50/40 Eibachs for £167 delivered. They are traders on here and were amazingly quick with the delivery. If you drop them a pm they will tell you what you need for your car, I believe they also do the H&R kit that Ajax was talking about. I'm very happy with mine and I know either set will work great on your car.
    Tiffy's Avatar
    Mar 2013
    Warwick
    354
    Got my Eibachs from Damian at DPM Performance....super fast delivery and look superb once fitted
    2007 Audi A4 B7 S-Line Avant 170 TDi Special "Black" Edition
    Genuine 19" x 9 Bentley GTC 5 Spokes
    Full Interior LED Light upgrade
    Ambiant "Submarine" Interior lighting
    Seat Leon Cupra R Splitter
    LED rear NumberPlate Upgrade
    Headlight, Fog Light and Side Light White Light Upgrades
    Eibach SportLine Springs 50/40
    Privacy Glass
    Apr 2013
    Greenwich, London
    27
    Thanks Chaps,
    I quite like the way my car sits at present, the reason I was keen on upgrading the springs was really for better comfort and handling, any chance of some pics of your cars with the uprated equipment so I can see the 'sit' of the car?
    Macdoon's Avatar
    Essex
    1,568
    Quote Originally Posted by Tiffy View Post
    Ditto
    Here's mine - Eibach 50/40
    A4 B8 (09) 2.0 TFSI (211)
    Black Gloss RS4 style mesh grille, Black Gloss fog grilles, Black Gloss splitter trim, Ice White fogs, Tints, Black A8 boot rings, Black Badges, Dynamik boot spoiler, LED interior, LED number plate lights, Brushed steel vinyl wrapped interior.
    Apr 2013
    Greenwich, London
    27
    Looks great...thanks.
    Jan 2013
    Moray
    228
    Thanks Chris,
    only vag owners call them diverters, they're BOV's or blow off valves. On vag petrol turbos they are recirculating but forge make a stronger version for higher boosts.
    Audi A4 (B7) 2.0TDi S-Line Avant Quattro - Steve Edition in Lava Grey
    BBS Wheels|arm rest|ambipur|345mm S4 brakes|PiperX panel filter|cupra R splitter|Greenstuff Pads|Retrofit Cruise control/DIS|Retrofit Audi Phone|Dension iPod|
    Full VCDS equipped for the Moray area
    Apr 2013
    Greenwich, London
    27
    Thanks for the insight Dave.
    Apr 2013
    Greenwich, London
    27
    I'm assuming that my current springs are the traditional s-line set up - can you tell from this image of the rear wheels (wheels are 18")?012.jpg
  1. satnavi upgrade for s3
    By dunk in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th October 2004, 15:49
  2. Brake & Suspension upgrade for A8
    By imported_WIL9598 in forum Handling
    Last Post: 11th August 2004, 11:15
  3. k04 turbo upgrade for 98 a4
    By Danielson in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th July 2004, 15:52
  4. Newbie here - performnace upgrades for A4 TDI's?
    By ping in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th December 2003, 13:38
  5. First Upgrade for Audi 1.8T
    By K212 in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th June 2003, 06:13
