Volks AutosMonster Motorsport
    Sep 2010
    19
    Red brake warning light but only when warm
    I have a B7 2.0 tdi and I'm getting the red brake warning light, but not on cold start up only when the car is fully warmed up.
    I've replaced the batterry but it is still doing it?
    I used to have a B6 S4 and that did it also but only on cold morning / cold start ups? Any ideas?
    Is it likely to be the brake fluid reservoir sensor?
    Many Thanks
    V6 Quatt's Avatar
    Feb 2008
    783
    Check the reservoir levels first and top up if required usually if levels slightly low will bring light on
    Torque the Torque
  1. Intermittent brake warning light on DIS when firing up my 2005 A4- B7
    By psychopomp1 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st October 2013, 11:40
  2. Red brake warning Light
    By R32 DBP in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th June 2012, 00:33
  3. HELP!! Red brake warning light on DIS screen at roundabouts
    By drewbee in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th January 2010, 12:43
  4. Brake warning Light
    By imported_Smudge973 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd January 2005, 19:17
  5. Intermittent Brake warning light - WEIRD
    By manikm in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th May 2004, 22:20
